HOW TO REMOVE MY WASHER BEARING TO CHANGE THE SEAL?
THE WASHER LINKS SO I HAVE TO CHANGE THE SEAL. THE WASHER BOTTOM IS DIFFERENT FROM ONES SHOWN ON YOUTUBE.the technician said he does not know how to dissemble that model. I need to know how to take out the bearing and the seal.I took everything else out already.
  • Washing Mach... Master
  • 5,323 Answers
This might help
HOW TO REMOVE MY WASHER BEARING TO CHANGE THE SEAL - remove-washer-bearing-change-seal-qwraf2tofhw5f1pyjgshzkpc-3-0.jpg
remove-washer-bearing-change-seal-qwraf2tofhw5f1pyjgshzkpcHOW TO REMOVE MY WASHER BEARING TO CHANGE THE SEAL - remove-washer-bearing-change-seal-qwraf2tofhw5f1pyjgshzkpc-3-9.jpg.net/uploads/images/remove-washer-bearing-change-seal-qwraf2tofhw5f1pyjgshzkpc-3-9.jpg
Posted on May 14, 2015
  • Jorge Rendon
    Jorge Rendon May 14, 2015
    are u talking about a belt drive and not a direct drive? you might have to remove from the bottom the mode shifter, the splutch assembly and the its fairly basic when u look at ir and see which screws need removing. some are hex screws, but u will have to remove the tub nut from the top side inside as well first after pulling out the agitator
How do i change a tub bottom seal and bearing which is giving trouble to pry out and is leaking water when spinnig
you say u have removed the nut and washer , from bottom usually it takes a spanner wrench to do that, after removing it may be hard and u have to pry it as it can stcik pretty well
Sep 17, 2014 | GE Washing Machines
My maytag washer model LAT9536AAE is leaking at bottom of drum at gear case how do i remove drum to replace seal
Unfortunately need special tool to take get to these parts and i suggest to whoever does this job to also change the bearing kit or problem will re-occur. 20 years experiance on these models.
Part #'s needed 6-2095720 and 6-2040130
Jun 04, 2011 | Washing Machines
Whirlpool Front load washer - wfw9400sw01. Sounds very loud during the spin cycle. Suspect a bearing issue. I have pulled the back plate off. Pulley, belt, shocks and motor all appear to be fine. What...
A loud rumble noise during the spin cycle is a good indication that the bearings have failed. The bearings are located in the rear outer tub. See link http://www.appliancepartspros.com/part_details.aspx?part_id=4426951 There are actually two bearings an inner and an outer bearing plus a seal. Water must have leaked past the seal causing the inner bearings to corrode. Once they start to rust, it just gets louder and louder. You are correct that Whirlpool does not sell the bearings and seal separately, but you must buy a new rear outer tub currently the price is over $400.
I had it happen to a different brand of front load washer and was faced to either, replace the rear outer tub, junk it or figure out how to replace the seal and bearing. I opted for the last and did some research on finding replacement bearings and seals. I had to tear the washer apart to get the bearings, then pound out the old ones to replace with new ones. It been working find for the last 2.5 year so far.
I found a website that might help you locate bearings and seals for your machine. http://www.hometask.com/washerrepair.aspx The site has a video on how to tear down your machine and shows you how to remove and replace the bearings. He might have the ones that you need on his site. Hope this helps you.
Apr 25, 2011 | Whirlpool WFW9400S
I've recently done the roller bearing fix on my FAV6800AWW, now..
cysloane
You have a Tub Seal leak for sure. Did your Clutch Pulley use the upper bearing ring? If you don’t have any Outer Tub bearing noise you may get around replacing the Outer Tub Bearings.
Take a look at these links and see if they will help. Getting the Spinner Assembly removed without breaking one off requires care. Soak in Liquid Wrench or PB Blaster. Even after doing that I broke one off. I had the bolt hole drilled out and Stainless Steel Helicoil inserted in.
Here is the process for a Series 10 machine I did a tub seal replacement on. If you follow my post I’m a DIY’er with basic mech. skill sets. I’m a Electronic Technician by training and and learned craft skills. I feel you can do this if you felt OK with my Clutch Maintenance/Replacement post.
I would replace both the Tub seal and the Tranny O ring seal.
I used an air impact tool to remove the Spinner Bolts and the 1.75” Spinner Nut. You might be able to get away from using the Spinner Nut removal tool if you lock the Spinner Assembly as shown on page 47 in the SM.
See this post for links on Tub Seal and Outer Tub bearing replacement.
Good luck and I feel you can do this. I’m no expert but will try to help you……..Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water keeps getting into my bearing.
I feel you have a Tub Seal leak.
Did you replace the Clutch Pulley or a repair service?
You are talking about the Clutch Pulley One-Way Roller Clutch bearing in the white bearring plate correct? The First two digits of your serial number are 12 thru 17. What are the first two digits of your serial number?
To replace the Tub Seal you need to remove the spinner assembly. That means you have to remove the outer tub. A bigger job but several on this forum have completed it including myself two weeks ago on a Series 10 FAV6800A.
I will point you to a link most recently where a form member replaced Outer tub bearings on his Series 15. If your wash basket spins up to 850 rpm with no Outer Tub bearing noise I would just do a tub seal replacement this round.
You would need the Tub seal see Sears Parts Direct. I would also pick up the Tranny O-ring seal (series 10) .
Some links on Outer Tub Bearing replacement.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
If you replace the tub seal make sure you remove this sleeve that will more than likely stay on the Spinner Support when you remove. See Page 49 of the Service Manual. Here is a real world pic of the sleeve on the Spinner Assembly.
I did break off a Spinner Bolt even after heavy soaking in Liquid Wrench be careful;
There should be six there oops!
Good luck and post back if I can help.....Rich
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Wheel bearings on 1988 chevy S-10
remove grease cap,brake caliper, then remove nut holding rotor now remove rotor, remove grease seal now both bearings should be out ,if replacing races then punch them out and tap new ones in, repack new bearings with grease install rear one and install new grease seal, slide rotor on slide frt bearing on, install washer and nut, tight a little to nearest cotterpin hole,put cotterpin in and put caliper on, hope this helps,good luck.
Oct 27, 2009 | 1988 Chevrolet S-10
How to change my front differential seal and bearing ? passenger side. I bought a new wheel bearing because of a humming sound on passenger side and doing so saw leaking seal and maybe the humming was...
That will be a Huge job. The whole front diff must come out of the car and the case will need to be taken apart to even gain acess to the carrier side bearings.
The hub bearing is where the wheel bolts up is that maybe what you are talking about?
Also the axle seal isn't that bad to do you need to remove the cv shaft then it's just a simple remove the seal and install the new one.
But all of these jobs will be big ones.
Oct 13, 2009 | 1999 GMC Jimmy
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
Reinstall the differential pinion shaft.
  1. Install the differential pinion shaft.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
    Remove the axle shaft.
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
  1. Lubricate the new rear wheel bearing.
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Feb 22, 2009 | 1999 Isuzu Rodeo
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Feb 06, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
