Outdoor unit noise and fan do not start. - Heating & Cooling
  • kenscampers Apr 07, 2015
    Hi sajjan patel, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 10 Answers
SOURCE: fan motor of my Panasonic
Do you know a service tech? Wholesale houses have generic motors for these now at about 1/3 less then normal price. Warning be prepaired to pay a higher then normal price due to the copper shortage...
Posted on Apr 26, 2008
james3751
  • 614 Answers
SOURCE: outdoor unit fan making noise when running sounds
Bearing in fan going out. Let it run till it quits or call service tech to change motor. Fix cost about 250 to 300 dollars. russ
Posted on Jul 22, 2009
  • 3 Answers
SOURCE: Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Posted on Aug 14, 2009
kingbrizzle
  • 407 Answers
SOURCE: 38CKC060 Carrier. Outdoor unit-fan does
It sounds like your fan motor is burnt up. If the noise you are hearing is coming from the motor itself, then it's going to have to be replaced. One way to check this also is to turn the unit off and try to turn the fan blades by hand, if you cant get to it, then use something skinny and long enough to drop through the opening on top. If there is any resistance, than its difinitly a bad motor. If the noise you are hearing is coming from the compressor, then your fan motor still might have a chance and only needs a capacitor which is a round or oval part inside the units electrical compartment. Depending on how mechanically inclined you are, it is possible to fix these yourself. Just a warning though, if your fan hasn't been running and the compressor has, it can or could burn up the compressor also. This is another reason why it can be hot inside the cage. Your compressor will go into internal lockout if it gets to hot and will not come back on until it cools, but it can only handle so much. Hope this points you in the right direction and good luck!
Posted on Aug 05, 2010
caroldon
  • 17129 Answers
SOURCE: outdoor unit on of my
If this is an old unit is is possible that the compressor is vibrating with the load. check and see if the mounting bushes and the foundation is tight and clamped properly. If not the unit must be removed and plugged well into a good foundation. Also check the mounting bushes of the compressor , If this wont solve there is fault within the compressor , possible low lubrication that make it vibrate which might require a consensus and estimate.-- specially if the cooling is going down.
Posted on Aug 22, 2011
Outdoor unit fan makes noise?
Could be a number of things from a foriegn object inthe way of the , a bent blade , bad bearing in the motor. Find a hvac guy you trust to take a look at it.
Nov 26, 2011 | Heating & Cooling
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
Is it normal for the outdoor unit on my coleman h/p to make a surging humming noise? the fan does not run during this period, approx. temp. is 28 degrees F. the fan runs 30 seconds befor the unit...
Sounds like your unit is going into defrost mode. When this happens the fan in the outdoor unit shuts off so you get more heat in the outdoor unit to defrost the coils. The heatpump is basically in A/C mode during defrost and the electric heat strips will kick in so you don't feel a cold blast of air in the house.
Jan 03, 2011 | Heating & Cooling
When turned on split unit (heating)it was making a rattling noise. What could be the problem. The unit is on my roof
I think you mean in outdoor unit fan. Check the fan blade- may be broken or bearing problem with fan motor.
Dec 02, 2010 | Heating & Cooling
Weatherking heat pump sounds noisy but has a 20 degree air difference from intake to vents, is this normal?
Without hearing the "noise" it is difficult to diagnose via internet; however, I can tell you that the 20 degF temperature difference is a good sign.
If the noise is at the outdoor unit, try to determine if it is the casing or something else. Sometimes the casing can rattle and/or vibrate that can cause a sound. Sounds can also come from refrigerant lines rubbing against the casing. Other noise sources at the outdoor unit are the fan motor, fan blade assembly, and compressor. You can remove one of the fan motor wires from the contactor, tape off the end, and start up the unit for a few seconds to see if the noise is still present. Then you can replace the wire and remove the compressor wires from the contactor and repeat the test. This will help you determine where the sound is coming from.
If the sound is coming from your indoor unitl, the most common sources are loose tape, Blower wheel, blower motor, or blower housing. Also look for loose panels.
Without being onsite with toolbox in hand and being able to actually hear the sound, I hope you find this information to be helpful to you moving forward. :-)
Jun 07, 2010 | Weather King 12AJA4801AH Air Conditioner
Outdoor fan does not come on
most likely it the the cap that is bad. Is this in heating or cooling mode?
Jun 03, 2010 | Heating & Cooling
Our air con runs, on heat, and after a time cuts out, blows cold and makes a sort of hissing noise (but not a real hiss) and then shuts down. It then restarts after a couple of minutes. Is this normal?
Yes.Think of a heat pump as a A/C in reverce in cool indoor coil is cold&outdoor coil is hot.Naw indoor coil is hot &outdoor coil is cold&fan is pulling in cold air from outside.its going to iceup& go into defrost cycle.If your unit has a timed defrost every 30,60,or90min.(witch ever yours is set for)Defrost control board checks a sensor on cond.coil,if it is frozen unit goes into defost.You will here a swishing noise,iis the reversing of refrigerant.you will also notice the outdoor fan is not operating&at termanation of defrost fan will blow out steem.the other metod is on demand defrost.when coil freezes unit defrosts.
Mar 02, 2010 | Heating & Cooling
Outdoor unit fan making noise when running sounds
Jul 22, 2009 | Carrier Heating & Cooling
Outside fan does not kick on just buzzes
The buzzing noise sounds like the contactor is energizing and if it is then you need to check to see if you have power 230 volts to the outdoor unit, if not, check the fuses or breaker, if you do have power then you may have a broken or burnt wire inside the outdoor unit.
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
