Question about Trueshopping NEW 2 STROKE OIL FUEL PETROL MIXING BOTTLE FOR STRIMMERS CHAINSAWS HEDGE TRIMMERS & MULTI TOOLS 25:1 50:1
Fuel 2 oil mix on Johnson outboard 1964 -18h - Trueshopping NEW 2 STROKE OIL FUEL PETROL MIXING BOTTLE FOR STRIMMERS CHAINSAWS HEDGE TRIMMERS & MULTI TOOLS 25:1 50:1
  • 4 Answers
50 to 1 all ways go for the higher as the oil is lube and a hot outboard needs it if you are wrong it will still run hard to push a boat home but in this case 50 to 1 is the one be safe on the water
Posted on Apr 19, 2015
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Do you mix the gas or just straight gas, where do you check oil
that old oil is to be mixed into the fuel 1 pint per 6 gallons of gas . only other oil is the gearcase lube
May 15, 2016 | Boating
1981 70 hp Johnson seahorse outboard motor oil mix ratio please
50:1 Ratio One pint of 2 cycle oil to six gallons of fuel.
Dec 28, 2014 | Boating
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
1999 Johnson 70hp 2 stroke outboard how can I disconnect the self mixing oil tank and premix oil and fuel myself?
the self mixing use variable rate which is much better then mixing it yourself. why would you want to change it?
Mar 18, 2014 | Garden
What is the gas/oil mix for an 80 hp johnson outboard motor
Even thought there are many expert tech's with sometimes more years of experience on this site than some you may find working in a repair shop, and of course many that simply give you their guess as the correct answer. I would recommend calling a Johnson Outboard Dealer or an outboard repair shop.
Jun 12, 2013 | Boating
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
Do i need to mix fuel for a 1988 15hp johnson outboard motor J15RCCS?
Yes.Fuel mix is needed.Mixture is 50/1 fuel /oil. Eg.50 litres of fuel/1 litre of oil.Oil bottles you buy have measurements on the side of them.Hope this helps
Aug 29, 2009 | Boating
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Trueshopping NEW 2 STROKE OIL FUEL PETROL MIXING BOTTLE FOR STRIMMERS CHAINSAWS HEDGE TRIMMERS & MULTI TOOLS 25:1 50:1 Logo
189 people viewed this question
Top Trueshopping Garden Experts
Dennis Key
Dennis Key
john h
Are you a Trueshopping Garden Expert? Answer questions, earn points and help others
