Question about Vizio VX37L Television
Vizio tv has orange light on panel no picture
5 Suggested Answers
  • 59 Answers
SOURCE: Vizio tv orange light on, not blue, won't bring up picture
if orange it is on stand by mode ,the cable that you changed is it power cable if yes then you used wrong one it may affect, i think you need to check power supply board . also get other opinion too. good luck
Posted on Apr 29, 2010
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
budmrtn
  • 11361 Answers
SOURCE: Tv will not come on. The white vizio light will
It is detecting shorted circuits so it goes into shutdown and try to restart over and over again. You need to do in-depth troubleshooting to find out why.
Please read my guide below:
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 27, 2011
e-Guru
  • 3917 Answers
SOURCE: TV turns on ,VIZIO emblem lights up,then the VIZIO
Hi
It sounds like bad power supply capacitors. Take it apart and take a look and replace them. Also try this:- unplug the TV from the wall and hold down the power button for a minute and then plug the TV back in outlet and turn on.If the power is good, I suspect the issue might actually lie in the mainboard.
You can check this. If you have a multimeter you can check between ground (any metal of the case) and one of the wires coming from the power supply is supplying 5VDC standby. If it is and the indicator light isn't on, the mainboard is likely at fault.
If there is no 5VDC standby voltage being supplied from the power supply, the fault is in the supply.
Maybe the mainboard has a short that is killing the power supply or the inverters.You have to buy a replacement.
Please get back to us if you have further query or else please accept this "particular" solution.
Thanks for contacting fixya.com
Posted on Sep 19, 2011
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
Vizio p50hdtv10a led light blinks 10 times when powered off
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 16, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
Apr 29, 2010 | Vizio L32 32 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio VX37L Television Logo
70 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
