Question about Maytag Washing Machines
Where do you put the soap in a Maytag Neptune front load washing machine
    Top Expert:
  • Maytag Master
  • 43,095 Answers
We always use liquid and just dump it in the open door before clothes are added .
Posted on Apr 06, 2015
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
SOURCE: maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
  • 298 Answers
SOURCE: water left pooled inside maytag neptune front loading washer
Possible explanation: Some water is left in the hose going up to the drainpipe b/c the pump can only pump water with water, not air... so when the last bit of water is sucked up, it 'stays' just the other side of the pump exit nozzle and keeps the drain tubefilled. This water gradually leaks thru the drain exit valve and back into the machine, sometimes siphoning standing water in the drain trap with it.
The valve is either electric solenoid or plastic/rubber clapper in a cylinder. Your call whether to fix or not depending on ease and cost. Probably a $20.00 part.
Cheers!
Posted on Mar 26, 2009
Where do you put the soapin a maytag neptune
On the neptune washer, on the top there is a dispenser on the left hand side, lift up the lid, there will be 3 compartments, the compartment closest to the control panel is the one you put the soap into, the middle compartment is for bleach, the other one is for fabic softner.
Aug 15, 2012 | Maytag Neptune MAH6500A Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    What do i do when i put double the amount of soap in the washer
    Nothing. But the wash load may need an additional rinse or two afterwards.
    Sep 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Maytag front load machine has a hidden mold odour coming from the machine somewhere, but I cant locate the origin.
    you could try a small amount of soda crystals put it in the soap draw about half the amount you would normally use of regular soap powder and put it on the hottest wash it will break down any gunk or loose limescale which could be causing the smell,
    Mar 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Why does my Maytag Neptune Washing machine smell like rotten eggs everytime I turned it on? Maytag Neptune MAH7500AWW Serial 70802618ZM
    you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
    Nov 08, 2009 | Maytag Neptune MAH7500A Front Load Washer
    My Neptune front load washer has a foul odor. I have tried the HE tablets, wiping it, etc. but it smells bad. When I spin it with my hand, there is water in the background. How do I get rid of the smell?...
    Add 3 cups of Sugar Soap concentrate. Then fill the machine and leave it for 24 hrs.
    Then put it through wash cycle with no clothes.
    If not fixed........machine has to be stripped apart and manually cleaned.
    Oct 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My Neptune will not rinse all the soap from laundry, have used extra rinse cycle and using less soap.
    are you using he detergent? its a must in this machine also are your close comming out soaking wet ?
    Aug 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag front loader washer--door won't open but lock light off
    Open the soap dispenser. Look down in front of the fabric softener dish.
    You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
    The door should open.
    If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
    Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
    SUDS error on Neptune washer
    It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
    Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    26 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
