Question about Frigidaire Freezers
I have the GLFU1467FW0 model Frigidaire freezer, and the temperature alarm won't stop going off. How do I flip it off for good? Pressing the alarm reset button does nothing.
Nothing is wrong with the freezer. Please, just tell me how to turn the temperature alarm off completely so I can get some sleep.
  • Official Brand Answer
  • 2,267 Answers
Hello Whywhywhywhyshame, thank you for your post!
Based off the information you have provided the temperature alarm on your Frigidaire freezer will not stop going off. This sounds like a possible problem with your sensor or control panel. I would recommend performing a reset on your freezer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not help resolve your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
Posted on Apr 13, 2015
Tech007
  • 63 Answers
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Posted on Aug 29, 2007
the dr
  • 447 Answers
SOURCE: Frigidaire 25' chest freezer alarm goes off eventhough it is very cold
The temp sensor for the over temp alarm is probably maifunctioning if you are sure that the temp isnt rising
Posted on Dec 27, 2007
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
diths_kri
  • 67 Answers
SOURCE: Frigidaire FFU20F9G (model FFU20F9GW3) temperature light is on
if the gasket is still sealing allaround the door then u shouldnt be losing any cold. try defrosting the freezer cleaning it out and firing it back up.
Posted on Jan 07, 2009
Several things could cause this. To check most things you will need to remove the back wall of the freezer to see the evaporator. It is possible the freezer is low on gas. If it is the coils will usually appear to be only half frosted or less. It is possible the defrost is bad ( I assume this is a frost free) In this case the coils will be totally clogged with ice and no air can circulate. If so you'll most likely have to replace the bi-metal... a circular looking part about the diameter of a quarter clipped onto the coil with 2 wires leading from it. This may also cause the fan to stop running from ice accumulation...or the fan itself could be bad which would also cause a partial meltdown. Unless the machine needs gas an appliance repair person will probably charge you around 100 bucks for most of these repairs..gassing it of course will be more and there is no guarantee how long the gas will stay in it as most leaks are difficult, if not impossible to locate. Hope that helps !
Posted on Jan 12, 2009
Alarm go on with no apparent reason
Thank you for your post, michael!
I see that the alarm inside your Frigidaire freezer continues to beep it sounds like a potential issue within your control panel or thermistor. Your alarm will beep to inform you that the inside of your freezer is reaching high temperatures. Performing a reset on your appliance could help correct the problem, to perform a reset you need to unplug your freezer or flip the household circuit breaker off for ten minutes. I hope this has been helpful. -Matt
Oct 13, 2014 | Frigidaire Freezers
Red alarm light flashing
Good Morning Friend, thank you for allowing me to assist you!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause. - Z
Jul 18, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
The temperature alarm is going off model no. GLFC2528FW4
Good Afternoon Friend,
I understand that the temperature alarm is going off, on your Frigidaire freezer, model# GLFC2528FW4. To deactivate the alarm, you will press the "Alarm Off" button. If the alarm continues to go off, make sure that everything is staying frozen inside of your freezer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire Freezers
Door ajar light will not go off
Good Morning Friend, thank you for your inquiry!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your freezer by unplugging it or flipping the household circuit breaker. It is best to wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Best regards! - Z
Jun 14, 2014 | Frigidaire FKFH21F7HW Freezer
Frigidaire freezer temperature alarm on but freezer is working
Good Afternoon Friend, this is Z. Thank you for your inquiry!
When your refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the alarm, you can depress the ALARM OFF button. However, if you have already done this, try once again unplugging your refrigerator or flipping the household circuit breaker. It is good to wait approximately ten minutes and then turn on your refrigerator. If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Jun 05, 2014 | Frigidaire Freezers
Frigidaire upright freezer
Hello Susan, thank you for your post!
Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Dec 07, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
Door ajar light lit with door closed
Good Afternoon Don, thank you for allowing me to assist you!
Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the red light will glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Oct 12, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door left open for about 90 mins on freezer now red alarm light is on all the time?
Good Morning Martin, thank you for your post!
Oct 04, 2013 | Frigidaire FVE145FF Upright Freezer
Temperature alarm sounding. freezer still running & it's only 7/8 years old.
Good Morning Bob, thank you for your post! Did the unit previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the unit. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the unit may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
Aug 09, 2013 | Frigidaire Commercial 19.53 cu. ft....
Freezer alarm
Upright freezer door was ajar, alarm went off. Where is the reset button? Product is Frigidare.
Jun 02, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezers Logo
392 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
