Question about Refrigerators
How do I remove the freezer drawers
How do I remove the Drawers on my F&P RF610ADUX French Door Refrigerator. I need t clean the condensate tube.
SOURCE: Removing the refrigerator drawers from the Electrolux side-by-side refrigerator
Got it. My mother got one of these fridges and was frustrated with the drawers not sliding off to clean. It is designed to dissamble the complete drawer assembly. Start by removing the glass from the top of the chill zone drawer frame. Next grasp the white piece of plastic that the chill zone is written on and pull up. There are 4 pegs which affix the drawer assembly to the fridge. The front two pegs will pop out and then the rear will easily pull. The top drawer assembly must be removed before the bottom two drawer assemblies can be removed.
I also noticed the plastic pieces and tried to pinch them but I couldn't get them to budge. Once I saw the 4 pegs, it made sense.
Posted on Oct 25, 2008
SolutionGuy
  • 331 Answers
SOURCE: I have a ge french door refrigerator with two
Hi Laura,
The repair guy did what any repair guy would have done under a warranty situation such as yours... door gaskets. I presume he explained why he was doing what did ("why's" are important, ya know...). If he didn't, let me run through it real quick, OK?
Warm air holds moisture and cold air doesn't... that it in a nutshell. But what's important to note is that if there is an air leak inside your freezer you'll notice it just as you have, with condensation forming. This tells the repair guy that cold air is escaping and warm air is entering the freezer. The first place to look is the door gasket and that's why he replaced it. But now you know it wasn't the gasket, right?
So the repair guy didn't find the source of the air leak. It happens. The reason is that most "factory" tech's are trained on the fly and have the habit of not looking too deep into a problem 'cause they're warranty guys. They get paid whether or NOT a problem was fixed. See? Independent repair guys like me only get paid WHEN the job is fixed. So there's a GREAT incentive for me to get it right the first time, right? (I'm not "bashing" them. I'm just clarifying that warranty repairs are hit and miss at best.)
The thing you gotta think about is "How many places are there for cold air to escape and warm air to enter?" The answer to that question is "4". Yep. FOUR places that this can happen and each of them have to be inspected for evidence of moisture. They are;
1.) Behind the fridge where the ice maker water tube is inserted through the cabinet and into the freezer.
2.) Behind the fridge where the wire bundle enters the freezer compartment.
3.) Behind the fridge in the compresser compartment where the evaporator drain comes OUT of the freezer compartment.
4.) The door gasket.
Since your unit is still under warranty I certainly wouldn't expect you to chase these down for yourself. You should call GE again and have the repair guy come do this for you (print this out so you will have the above checklist). This is to protect your warranty, by the way. If you (or an appliance repair company NOT authorized to work on it) work on it, you run the risk of voiding the warranty altogether.
There's a product on the market called "PermaGum" (here's a link). It's used to seal air leaks such as this. When you talk to GE, try to insist that the tech have some on his truck when he arrives... I have the feeling that he'll need it because I suspect a leak is occurring in one of the top 3 areas I mentioned above (either that, or he didn't install the door gasket correctly in the first place).
As an aside? Just a tip/hint... I know that your fridge is new and all, but to KEEP the door gaskets like new for (almost) ever, use Vaseline on them. Yep, Vaseline. Open the fridge door, dab your finger into the Vaseline and smear a light (light) coat of it on the door gaskets all the way around. This will do 2 things;
1.) It'll keep the door gaskets from ever drying out.
2.) It'll provide a very good and air-tight seal when the door is closed. (air leak, Laura?)
There ya go! I hope this has helped you in your quest to rid you freezer of pesky condensation. If so, please remember to rate this as "It fixed my problem", OK? After that, you can mix up a Mojito and bask in the knowledge that you are a completely informed consumer when the GE guy gets there to finally fix your fridge.
Take care,
SG
Posted on May 07, 2009
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
  • 7 Answers
SOURCE: Samsung refrigerator - frost on outside of freezer drawers
try checking the freezer door seal.
if slight gap anywhere around the door seal drawer fronts will frost up.
warm seal up with hair dryer and ease seal out with your hands..
problem often happens with door reversal.
Posted on Oct 09, 2009
heatman101
  • 43501 Answers
SOURCE: I have an ge french
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Posted on Sep 27, 2010
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
Where is the drain,and how do i get to it? model rf26vabwp it has french doors
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it's plugged with **** and fungus and yecchy stuff. Clean it out and reinstall it.
Jun 14, 2014 | Sub-Zero Bottom Freezer Refrigerator
Water under fridge sometimes
You may want to remove all the food, unplug your fridge, and the out the whole thing...melting the ice and cleaning out all the unwanted water. The drawer will be removable, and you can dry under it. Also check the overflow tray under the fridge, if there is one...it'll be full from all the melting.
Jan 24, 2014 | Whirlpool GX5FHTXVA Bottom Freezer French...
My bottom freezer not closing properly
Pull both drawers completely out of their locations, clean off the slides that they each normally rest on. Clean off the surfaces beneath where they sit. Now, if they are both the same width and height, switch them and see if the problem is solved. If not, check the actual drawers to see if their sliding surfaces are cracked or covered with any kind of junk. You should be able to get everything to fit with these procedures.
Jan 12, 2013 | Maytag MFD2560HES Bottom Freezer French...
Removing samsung freezer drawers
There are 3 bolts that hold the bottom of the freezer door in place, if you remove them the door will fall to the floor then youmcan pull it off then you can access the drawer
Sep 07, 2012 | Samsung RFG237AARS Bottom Freezer French...
How do I clean around the rim of the refrigerator drawers?
Samsung draws are removable, but they are a pain and have to be pulled out, then lift up which allows you to bet the nylon wheel guide to dip under stops, and sometimes takes a little force taking out, and putting back in.
CERACOAT-NANOTECH.com
Feb 22, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
Dec 14, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
My refrigerator won't cool (freezer still working)
The temp sensor is the most likely cause of this problem. However, you have other possible options that you can test and check:
likely the problem with your fridge is a bad dumper control. This is a part which operates with the air flow from the freezer into the fresh food compartment.
The dumper control is located in the in the upper left corner in the fresh food compartment.
Sep 21, 2009 | Maytag MFD2561HE Bottom Freezer French...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
