LED funtion display doesn't work - Computers & Internet
  • 2,072 Answers
Some laptops require a utility software to be installed for the function keys to work. Check out the manufacturers site for your model device.
Posted on Apr 06, 2015
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
2003 saturn vue driver window doesn't go up and down . The regulater and motor funtion properly . All other windows work correctly . The console switch on the left side is for both left sides wind
BY PASS SWITCH BY RUNNING A FUSED JUMPER WIRE FROM THE BATTERY POSITIVE TERMINAL TO WINDOW MOTOR CONNECTOR, HOT SIDE, AND A NEGATIVE WIRE BACK TO BATTERY NEGATIVE TERMINAL...IF WINDOW OPERATES....IT IS THE SWITCH
Feb 22, 2013 | 2000 Saturn SL
Ge JES0738 LED display is fine but turntable doesn't work, microwave doesn't start. Is it a fuse issue?
No! from the description it is one of the door switches that has become defective. The solution, all the door switches need to be tested to find the bad one.
Jun 13, 2012 | GE Microwave Ovens
Toshiba m100 my hand trying to have a power LED and battery LED fan works but I can not display the image signal.
If you see power lights but nothing appears on the screen, it could be a "POST" (Power-on Self Test) problem or simply LCD problem.
Here are some steps that you can try.
1. Remove the battery and the ac adapter then press the power button for at least 20 seconds to drain electric charges left from the system. (You may need to repeat this step to get it work.)
2. If above step doesn't work, try to plug in an external monitor and see if you get display from the external monitor. You may need to press the Fn + F10 or F6, depends on the key designed on the keyboard to toggle between displays.
3. If you get display from the external monitor, I'm sure your having problem with the LCD components. In this case, check and replace faulty LCD backlight, LCD cable or LCD inverter. The LCD inverter is often a culprit.
4. Try to reinsert the memory module/s (RAM) of the unit, try using one RAM at a time to see if it works. A faulty RAM will cause the issue not to POST.
5. If reinserting the RAM doesn't help, most likely your motherboard needs to be replaced.
Hope this helps.
Jun 03, 2011 | Toshiba Satellite M100 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
DTerm80 phone, how to get language on display back to english
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
Jul 28, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
I have a AIWA XR-MDS7 EZ sup mini stero unit, the lcd display is dead although the unit works I cannot tell what disc is playing or track number. Also I cant tell what radio station is playing. Everything...
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Dan
Apr 11, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
