Question about Measuring Tools & Sensors
I have a Briggs motor model 445577 type 0435 E1 that has a oil leak on the lower end that runs back and drips on the exhaust. Any suggestions?
2 Suggested Answers
  • 10865 Answers
SOURCE: White Smoke comming out of Briggs and Stratton 21 HP V2 engine.
The white smoke may have been caused by having water in the fuel, or fuel tank [due to condensation or exposure to rain and snow]. It may have been that the mower got tipped for cleaning purposes, blade inspection, etc. and oil from the low lying oil pan got into the piston.
Either way, I recommend installing a brand new spark plug and new gasoline [you can purchase a little gas siphoning hose for a dollar or so at any auto parts store] If you have gasoline left over in a can from last year it is safe to use it in your car as it mixes with lots of new gas, but not in your small mower tank as it is basically outdated fuel.
Posted on May 19, 2009
How to obtain and replace Briggs and Straton fuel solenoid on Intek Model 445577 type0110-E1
more than likely not they really dont go bad probably dirty carb rebuild it
Aug 20, 2014 | John Deere Garden
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 99 ktm 250 sx. Had to get cylinder replated and a new piston. I put the bike back together and oil was leaking from the front lower end of the cylinder and i wont idle. Took the bike back ap
If there is a leak in the head gasket it will never run properly. Maybe the carburetor is plugged if it has sat for a while. The gas/oil mixture can go bad over time. The leak could be from a loose gas line. Or possibly even oil dripping from the oil filter if you just cleaned and re-oiled it.
Aug 10, 2013 | Motorcycles
280H07-0166-E1 briggs engine blows smoke out exhaust
smell the oil if it smells like gas then the needle and seat in the carb is leaking if not remove the cylinder head and see if the gasket blew out and its sucking oil from the crankcase if not look at the bore for scores scratches and scraps
Aug 13, 2012 | Briggs & Stratton Briggs Stratton...
Looking for a oil filter # for a fram oil filter to fit a husqvarana yth2348 mower. thank mike
I don't think fram has a filter for it, but you can get the filter at NAPA, Lowes, Home Depot, O'Riley's, Sears, or any small engine shop. According to Sears Parts website the model # that you gave has a Briggs and Stratton model # 445577-0284-e1 engine; however a B & S or Kohler engine manufacturer's filter with fit your engine. They are interchangeable. The B & S part number is 696854 or 120485.
Hope this helps. Please vote yes if it did. Thanks
Nov 01, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 18 hp briggs and stratton engine that will not start
A few more things to check.
1. The oil level. If the oil level is low the oil level sensor will ground the ignition.
2. Check the wiring from the seat safety switch to make sure it is connected.
3. Follow the black wires from the ignition control module to make sure none of them are chaffing and do not have a chassis ground.
If you still have problems disconnect ONE lead from the oil level sensor and see if you have spark. Most of the time these oil level sensors are the common failure.
Kelly
Apr 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
141 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
