Question about Singer Handy Stitch Hand Held Portable Sewing Machine As Seen on Tv
Where do i get the needles with out getting them on line
  • 86 Answers
They appear to be standard sewing machine needles... available anywhere that sells fabric, etc. including Wal-Mart. Take one that you got with it along and ask the person cutting fabric if you're not sure.
Posted on Apr 06, 2015
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
How many. Do u need
Have them in stock
Call Wedtern Canada. Wayne
403 529 7965 moment singer dealersay have them in stock
Singer 3314c need help with timing
Hi the point of the hook should be in line with the needle and just above the hole in the needle with the needle 2.5mm up from the lowest needle position. The gap between the bottom line and bush should be 2.5mm in the lowest position
Sep 14, 2017 | Singer Sewing Machines
Needle Plate
Sometimes you have to manipulate the plate to get it to "settle" into its slots, but if it lined up before you took it off, it must line up now, IF your bobbin case is correctly inserted, which could be another possibility.
Jan 08, 2014 | Singer 8763 Curvy
Needle threader not lining up with eye of needle
On mine, I just pushed the needle threader to let it line up with your needle when you have the lever down, look at the little wire to see what it is hitting on the needle. My first machine with a needle threader had the little wire missing so I thought that I was doing something wrong, luckily JoAnn's had a Viking store inside and she showed me. So, I called Singer and they sent me a new one.
Jan 31, 2018 | Bernina Virtuosa 160
Line needle plate
try a new needle first, then if the needle doesn't line up with the needle plate, then the machine needs a ajustment or has a timing problem and needs to be checked at a sewing machine shop
Oct 01, 2013 | Singer 4423 Sewing Machine
When using twin needles only one line of stitching is stitching normally, the other line is jumping stitches. I have tried rethreading & changed the twin needle. With the first twin needle the left...
now that is strange. check your thread, now take that twin needle and try this, shove it very hard up into the the needle holder. my thought is that it is not up enough. because your problem is exactly what would happen should the twin needle be sitting too low. try shoving it up higher and test again.
Aug 26, 2010 | PfaFF Quilt & Craft Pro 7530
Problem: The needle threader does not line up with needle eye
Tr
Machines Support
For questions regarding Machine Support, fill out the Machines Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 774.
Technical Support
For questions regarding Technical Support, installing, updating, or using your embroidery software, fill out the Software Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 775.
General Inquiries
For general questions, please use the General Inquiries Form.
Request a Machine BrochureFill out the Brochure Request Form to request a brochure for your choice of machine.
Janome Mailing List
Click here to join the Janome Mailing List.
y this:
Mar 20, 2009 | Janome 6019QC Mechanical Sewing Machine
Thread skips
Well, Hello Kim. Once the Needle for the machine is changed, there is a good possibility of the timing of the stitches being altered and hence the problem.
  •  Firstly, make sure that the needle is in correctly with the scarf of the needle towards the hook. Take the needle plate off and the presser foot off.
  • Turn the handwheel towards you until the needle is in the lowest position, and on the needle bar you will see two lines somewhere near where the needle bar enters the machine.
  • When the needle is in the lowest position, the top line of the two lines should be flush with the body of the machine.
Jan 05, 2009 | Consew 206RB
Problem with automatic needle threader On Viking Designer 1 serie
Yes, I fix them all the time. You will need very good eye sight as the wire/metal hook is very small. If you get at an angle where you can see how the hook lines up between the metal flaps that hug the needle, the hook will probably be off center. You will need something very flat, but strong. I have use the exact-o-knife blade, in the handle of course, a knife, and a tiny screw driver. The hook has to line up vertically and horizontally. What usually happens is when we thread the needle it did not line up exactly, and putting pressure on the white tab, bends the hook. Bend it back and you are in business. If the threader does not line up horizontally, the needle threader may have slid down the shaft. This take a special tool. I purchased mine at Sears tools. There are 2 screws on the back of the threader. Move the needle to the highest position and after loosening the 2 screws, you can slide the threader up and down on the silver shaft, this is trickier, because the shaft moves up and down and rotates as it gets close to the needle. I use calipers/hemostats to hold the shaft while I line up the hook.
Hope this helps.
Dec 24, 2008 | Husqvarna Viking 1
How do I fix a timing problem with my singer sewing machine? The needle thread will not pick up my bobbin thread.
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
May 03, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 404 sewing machine
I would first make sure the thread tension is adjusted properly. if this does not fix your issue, check the point on the shuttle hook and make sure it is not broken off. it should come to a needle sharp point. if the tip is broken off it may not pick up the thread from the needle properly. then double check the timing and the needle shaft depth. first, make sure your needle is fully seated and tightened down. the groove in the needle should face forward. there are two timing marks on the needle shaft. at maximum depth you should see both lines and the top line should be right at the bottom of the needle shaft bushing. then as the shaft goes back up, when the bottom line is at the bottom of the bushing the point of the shuttle hook should be right behind the needle and centered in the indentation on the back of the needle. you may need to make minor adjustments on the needle shaft depth depending on what brand and type of needles you are using.
Mar 18, 2008 | Janome 4623 Mechanical Sewing Machine
Singer Handy Stitch Hand Held Portable Sewing Machine As Seen on Tv Logo
50 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
