Question about Saws
How do you release the blade on a wen 909 sawzall
  • 813 Answers
Hi,I dont know if its the same as dewart,but mine has a leaver on the side of the rubber grip wich you pull outwards,mine is on the right hand side on rubber grip that is just before the blade.
some times if it has not been used for a time gets a bit stiff,a bit of wd49 if this is the case.
hope this was some help.
Posted on Apr 05, 2015
rowdy45176
  • 2176 Answers
SOURCE: Cannot get blade to release
Will the collar on the Quik Lok Turn and if so how much? What you can do is spray some WD-40 on the mechanism to free up the collar, sometimes it gets gummed up from cutting. It should open and close with a snap, hope this helps
Posted on Dec 09, 2008
rowdy45176
  • 2176 Answers
SOURCE: I have a Milwaukee sawzall 6509-22 with a quick
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Posted on Jul 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: milwaukee blade holder replacement
piece of cake. the number you need is 14-46-1011 and the cost is usually between 15 and 20 dollars. it comes with detailed instructions and a exploded parts list for this. About 10 minutes tops. If I have answered your request would you please rate this response accordingly. and if you provide me with city state and zip I will try and find one locally for you if in U.S.
Posted on Sep 14, 2009
jrox55
  • 66 Answers
SOURCE: The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Posted on Mar 09, 2010
rowdy45176
  • 2176 Answers
SOURCE: Milwaulkee sawzall quick release wont
try using WD-40 first to loosen up pin and if not you might have to replace the quick lock assembly. ot a tough job about 10 minutes or less.
Posted on Jan 18, 2011
Saw blade jammed - cannot remove
Unplug from power. Spray blade locking mechanism with wd40 or similar lube. 1. If you have a quik release, work the release with a pair of channel locks while wriggling the blade. If not removed, you can remove the footplate from the saw and drive the pin out that holds the quik release in place, paying attention to how the parts reassemble. 2. If you have a set screw retainer, totally remove the retainer.
Sep 08, 2012 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
I'm unable to remove the blade from the quick change something won't release the blade model 6521-21
what you can try is to unplug tool and spray something like WD-40 on the collar mechanism and usually it is simpler for this to remove the pivot shoe and turn the collar and release until you can get full rotation and pull the blade out. There might be some dirt in the release mechanism not allowing the blad/collar to release. This is about the only way without having to remove the assembly. Let me know if you need more assistance
Mar 11, 2011 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Milwaulkee sawzall quick release wont release.Cam turns ok but pin is holding blade.Tried prying blade out w/vise grips-no luck
Jan 17, 2011 | Milwaukee Tool 10 Amp Sawzall Plus with...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Blade not releasing
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Cannot get blade to release from Sawzall Quik-Loc.
Nov 29, 2008 | Milwaukee Tool Milwaukee 10 Amp...
Saws Logo
544 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
