Question about Toys
Charged battery but it will not go. How do you test the gear shift?
I tested the peddle switch and it appears to work.
plz test all the wires and switches , the motor and its wires .
and the lights to be sure if the electrical circuit is ok
hope that will be well for you dear.
Posted on Apr 06, 2015
First noticed the idle was really high last night when I started it. It returned to normal pretty quick. Battery light was on fire a minute it went off, battery is only 4 months old. Today, riding home...
sounds like the charging system is not charging when the battery is low the starter will not disengage properly disconnect battery and charge it while battery is out with bike in a high gear 4th 5th push bike back and forth this should unengage starter once your battery is charged and back in bike if the starter engages and dis engages properly then you will need to test your stator output with a multi meter look on you tube for video to test stator good luck
Mar 17, 2015 | Motorcycles
4x4 low light on car will not move
The electronic module (located behind the glove compartment) controls the operation of the transfer case in response to inputs from the electric shift motor, 4x4 mode switch, CPP switch, BPP switch, DTR sensor, throttle position output from the PCM, front and rear OSS sensors, and the VSS. Do you know what DTC'S Are ? Diagnostic trouble codes !
P1804 4WD High Indicator Circuit Failure GEM GO to Pinpoint Test C . P1806 4WD High Indicator Short to Battery GEM GO to Pinpoint Test C . P1808 4WD Low Indicator Circuit Failure GEM GO to Pinpoint Test C . P1810 4WD Low Indicator Short Circuit to Battery GEM GO to Pinpoint Test C . P1812 4WD Mode Select Circuit Failure GEM GO to Symptom Chart. P1815 4WD Mode Select Short Circuit to Ground GEM GO to Symptom Chart. P1820 Transfer Case CW Shift Relay Coil Circuit Open or Short to Ground GEM GO to Pinpoint Test B . P1822 Transfer Case CW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1824 4WD Electric Clutch Relay Circuit Failure GEM GO to Pinpoint Test A . P1826 4WD Electric Clutch Relay Short to Battery GEM GO to Pinpoint Test A . P1828 Transfer Case CCW Shift Relay Circuit Failure GEM GO to Pinpoint Test B . P1830 Transfer Case CCW Shift Relay Coil Short to Battery GEM GO to Pinpoint Test B . P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure GEM GO to Symptom Chart. P1838 Transfer Case Shift Motor Circuit Failure GEM GO to Pinpoint Test B . P1846 Transfer Case CONTACT PLATE "A" Circuit Failure GEM GO to Pinpoint Test B . P1850 Transfer Case CONTACT PLATE "B" Circuit Failure GEM GO to Pinpoint Test B .
P1854 Transfer Case CONTACT PLATE "C" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1858 Transfer Case CONTACT PLATE "D" Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1866 Transfer Case Maintenance Required (GEM Only) (4-wheel drive operation can be restored by clearing the DTC and cycling the ignition.) GEM GO to Pinpoint Test B . P1867 Transfer Case Contact Plate General Circuit Failure (GEM Only) GEM GO to Pinpoint Test B . P1874 Automatic Hall Effect Sensor Power Circuit Failure GEM GO to Symptom Chart. P1875 Automatic Hall Effect Sensor Power Circuit Short to Battery (GEM Only) GEM GO to Symptom Chart. P1891 Transfer Case Contact Plate Ground Return Open Circuit GEM GO to Pinpoint Test B Your best bet , take it to a qualified repair shop
Apr 04, 2017 | 2002 Ford Explorer
95 GMC Jimmy two wheel dr the battery light will come on during shifting. Volts will go down and lights go dim. After it shifts gear it would go back to normal. Will repeat during shift gears or rpms...
like I see the problem ,the most common is belt not tight enough or alternator or battery
with a voltmeter check the battery voltage more then 13 volts. test battery with a load test
Sep 28, 2013 | 1995 GMC Jimmy
How do i get my gear shift unstuck on a 2007 chevy impala?
it should work off the brake if you push on the brake and it dose not unlock could be a number of things lets start with the switch at the brake peddle look under dash for push buttons that work off the brake peddle and make sure they have not come loose.
Aug 01, 2012 | MagnaFlow 2007 Chevy Impala - SS, 5.3L V8,...
Peg Perego Apache Jeep electrical problems.
start at the battery, then check the foot pedal then the shifter switch
Jul 14, 2010 | Peg Perego John Deere Gator HPX Ride on...
Cant push the button to put in gear
CHECK MAKE SURE BATTERY FULLY CHARGED IT HAS TO BE 12.5 VOLTS BEFORE THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID WORKS.IF BATTERY POWER GOOD CHECK BRAKE LIGHTS TO SEE IF BRAKE LIGHTS SWITCH IS WORKING.IF NO CHECK FUSE.IF FUSE GOOD BRAKE LIGHT SWITCH IS FAULTY. IT CONTROL THE BRAKE TRANSMISSION SHIFT SOLENOID ALSO THE NEUTRAL SAFETY SWITCH.IF FUSE AND BRAKE LIGHT SWITCH IS GOOD.YOUR PROBLEM COULD BE A FAULTY NEUTRAL SAFETY SWITCH OR BRAKE TRANSMISSION SHIFT SOLENOID FAULTY.
May 05, 2010 | 2001 Chevrolet Cavalier
2003 dodge ram 1500 quad cab will not shift out of park
There is what is called a shift interlock mechanism. It is suppose to keep you from putting it into gear withut putting your foot on the break.
Do a quick test. See if your brake lights come on when you press the brake peddle. If they do, you will have to go into the wireing of the brake switch and see if power is coming out of the switch to the interlock solenoid. If power is going to the solenoid, then you have a bad solenoid.
Hope this helps.
Apr 10, 2010 | 2004 Dodge Ram 2500
Can`t locate the fuse for the Brake switch. Brake light not working as well as 4 ways. Also shifter locked in Park
There are 3 fuses related to the problems you mentioned. fuse #13 20amp for the stop lights/fuse #15 5amp for the generic elec. module/powertrain ctl.
module/anti lock brake module and one you need the
shift interlock. Fuse # 28 10amp for the brk. shift
interlock/day running lights/bu lamp/tlr bu lamp and
4wd shift on the fly solenoid. The fuse block is behind
the panel on the left lower dash. You can check these fuse's first. But also, use a 12v test light to
check for power out of the bl switch on top of the
brake peddle assy. There is a red/lt green wire from
the bl switch into the colum to the shift lock actuator
check for power at this wire with brake peddle pushed
down. If the fuse's are good but no pwr. out of the
switch, replace the switch. Hope this helps.
Mar 22, 2010 | 1999 Ford Super Duty F 450
1995 toyota camry stop lights are not working
If the fuse is fine and the bulbs are good you should check with a test light if power is being supplied to the terminals if the problem must be reached in the brake switch is on the brake pedal. Thank good luck
Jan 13, 2010 | 1995 Toyota Camry
Can't get car out of park!!
This may seem like a silly solution but it's worth a try if it gets you out of this jam. I believe the Kia has a safety feature where it won't let you shift the car out of park unless the break peddle is fully depressed. Try stomping on the break peddle while you start the car. Then see if it will let you shift out of park. If this doesn't work try pumping the break peddle a few times and try it again. If this doesn't work check the fuse box. Maybe the fuse for the actuator in the gear shift lever that lets you take it out of park is burnt out. I hope this helps you out.
Jun 03, 2009 | 2006 Kia Optima
Toys Logo
818 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
