Question about Worldwide 1998 Dodge Caravan 3.3L Alternator - 90 Amps
My van starts up then dies there is fluids leaking in 2 places at the front part of the engine also. How can I fix this problem?
A friend broke the driver side headlight backing out of my driveway, and ONLY broke the cover of headlight it still works, and no body damage AT ALL. However when I went to go somewhere, it starts up then dies immediately, thought it was maybe a fuel shut of or along those lines, but there is 2 places where fluids are leaking at the front part of engine also.
    Top Expert:
  • Worldwide Master
  • 44,232 Answers
Better call a mechanic fluid leaks could mean soft plugs if motor froze or it could be cracked block .
Posted on Apr 05, 2015
Dodge caravan 2001 blowing burning power steering fluid.
I can answer some of your questions without being there in person.
The smell inside the van is from fresh air entering the venting system. Not sure why you don't get it from all vents. The fresh air intake is in front of the windshield and will pick up any smells from the engine compartment.
Loosing the serpentine belt would not necessarily cause you to loose ps fluid, but having a leak could drain the pump and damage the bearings in the pump, causing the pump pulley to drag on the belt.
The ps pump could be in the final stage of failing.
And the shaft seal in the pump could be leaking fluid onto the engine and exhaust.
Feb 23, 2013 | Dodge Grand Caravan Cars & Trucks
I have a 2001 ford winstar mini van, I drove it about 700 miles on a vacation, I parked the car at my sister's house it sat for about 4 hours, then started to drive for another 2 hours. I noticed some...
There are 2 cooling hoses that go to the radiator from the transmission. Hopefully it's one of these. The hoses are at the front of the vehicle or the right side standing in front of the vehicle. the stretch across the front to the left side. They are mostly metal ,but there is some rubber hose to it. The hoses connect to the radiator on the left side at the top and bottom of the radiator. If the hose blew out you can fix this with some new transmission hose. You will need a tube cutter, two hose clamps,a screwdriver, a razor blade/knife and 2 feet of hose just to be safe. Cut the metal tubing on each side of the rubber hose, cut enough new hose to go in it's place and use the hose clamps to secure it. If for some reason the metal tubing is bad,rust, you can do the same thing.
Jul 04, 2011 | 2001 Ford Windstar
My van is leaking radiator fluid but not from the radiator, it is coming from the engine, the hose goes from radiator to a metal tube that goes into the motor, this is where it is leaking from, is this a...
HI if the metal tube your talking about is front of engine.
yes it can difficult fix because that is your water pump.
put first check and see if hose clamps are tight if so. tack van
to service shop.
Jun 28, 2011 | 1995 Plymouth Voyager
Oil gushing from trans.??????? changed valve cover gasget oil pan gasket someone told me the rear main seal????? how can i b sure
If it in fact it is the main seal you should see tranny fluid leak at the point where the engine bolts to the transmission. With car in park and brake on, start engine and carefully look under to see where the fluid is coming from. If you see no fluid leakage, place the front end (this assumes front wheel drive only) on jacks stands and block the back wheels. Have a friend start the car and with their foot on the brake place the car in drive and SLOWLY remove their foot from the brake and allow the front tires to spin (DO NOT REV ENGINE) watch for leakage as wheels turn. If you see leakage at the engine/tranny mating surfaces then yes I expect it would be your main seal. I'd take avery good look at tranny cooling lines to and from the radiator, if these leak it is very heavy.
I hope this may have assited you,
Tom
Nov 08, 2010 | 1993 Mitsubishi Eclipse
When in gear can does not move
Check the transmission fluid,with the van at normal temperature and after runnig it through drive and revers a few times then place it in park and check it with the engine running,if it's down then top it up with chrysler type fluid and get the leak fixed,if it's not down on fluid then get a transmission shop to look at it.
Dec 16, 2009 | 2000 Dodge Caravan
Tranmission leak, just purchased the van it had been sitting for about 6 months, we have driven it for about 2 days and it started to leak. Dry seals?????
Probably, go to the auto parts store.They sell stop leak fluid for the transmission.
Its really best to get the van over head (ramps?) and look and see the leak and fix it properly.It could burn up the trans out away from home if your not careful.
Oct 29, 2009 | 1997 Dodge Caravan
97 astro van coolant & transmission fluid leak front of engine
sounds like a blown head gasket or cracked head- do not drive this vehical at all untill looked at by a shop
Aug 26, 2009 | 1999 Chevrolet Astro
I had the oil changed and the manual transmission fluid changed 2-3 days ago. I noticed leaking today on the right front tire side. A few hours ago it died. Still has power (lights, radio) but...
I don't believe the transmission fluid being changed would have anything to do with the engine being dead. You could have a tranny with no fluid in it and the engine would still run. Wondering if your engine oil got changed correctly. I would pull out the dipstick for the engine oil and see how much is in there. If this is an error from an oil change place that has caused your engine to die because of their negligence, then you may have a legal issue on your hands. Good Luck.
Aug 05, 2009 | 2002 Kia Sportage
My 2001 astro lost it's brakes and power steering at the same time. any ideas?
check the power steering pump to see if the shaft broke. remove the belt and pull the pulley on the pump, it should not pull out of the pump. If it does you need a new pump
May 12, 2009 | 2001 Chevrolet Astro
Noise in front end when steering wheel is turned
is your van 4WD, AWD, or rear wheel drive? if it is 4WD or AWD, the front axle seals might be going bad. PLEASE RATE MY ANSWER.
Feb 26, 2009 | 1997 Ford Econoline
Worldwide 1998 Dodge Caravan 3.3L Alternator - 90 Amps Logo
52 people viewed this question
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
