Question about Tools & Hardware - Others
Stopped working. Lights are flashing, checked all nail slots and gun. No misfires or jams.
sbg_ofp
  • 10 Answers
SOURCE: rapesco pro 140EL nail gun repair/ manual sought
Perhaps [url=http://www.tacwise.com/tools/view_prod.asp?code=21&back=2&type=1]This Link[/url] will get you going in the proper direction. It's not a schematic but it is the Tacwise homepage, hopefully they can be helpful to you.
Posted on Nov 05, 2008
SOURCE: dewalt dc618 wont drive a nail
problem solved.whoever had used the tool must have hit something hard because the drive pin had been pushed back just enough to stop it from cycling.
Posted on Dec 04, 2008
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 misfiring intermittently
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
  • 4 Answers
SOURCE: paslode 350s nail gun misfire
make sure nails are in correctly, put a battery that is FRESH off the charger in. if this does not work put a NEW gas cartrige in. if still fails read someone else's advice
Posted on Jun 13, 2009
Ihave a nail jammed in my gun,I believe there is a release gate but how to open it?
Is this a Dewalt gun?There is a faceplate in front of the barrel/slot. That's what you want to remove. Find the appropriate allen wrench and remove the bolts Your "jam" will be mostly exposed. 9 times out of 10 it's two nails that are wedged together or a bent nail. Using thin sharp tool or another nail pry the jammed nail(s) out. Note: be sure to keep that slot oiled, it is very important!
Jun 02, 2015 | Tools & Hardware - Others
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Misfires new gun
If your using refills that have wire holding the nails together.
Check to see if bits of wire, debris is collecting in around the striking hammer. I switched to paper and never looked back. Must have gone through 5k worth of nails and rarely jams. Other things to check,
1. Check the striking hammer, make sure it is not bent or damaged.
2. Check air pressure, Low pressure can cause jamming, misfires.
3. If the tool needs pneumatic oil, 2-3 drops before you start good rule of thumb.
4. Check spring return. Sufficient pressure must be maintained or the nails will not feed properly. Misfires, incorrect feed, jamming etc.
I had a Hitachi brad nailer and it was horrible. Fire 1 brad nail would jam or misfire. Did everything I could think of nothing worked. Put it up, got a Rigid brad nailer and never looked at the Hitachi again. :)
Sometimes you just get a lemon! (PS I understand you have a framing nail gun. Brad nail gun above is used for an example)
Hope this helps
Mar 24, 2014 | Hitachi KNR90AE Round Head Framing Combo...
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Why do these guns require paper over plastic heal nails.and can these guns inter change nails
The problem is that the nails could jam or misfire. On some plastic strip nails (brands), a piece of the plastic will prevent the nails from moving into proper position and misfire (forceing you to pull the pusher back and release against remaining nails, this sometimes makes the nails bunch-up). No big deal, try using various brands of nails and use the one that works for you. To make sure that the nails will work, place a strip of nails on the outside of the rails and align the first nail to the path of the driver, notice if the remaining nails align with the rails. The nails should enter the rails easily and the pusher should easily move the nails forward (do not let the pusher slam against the nails). Some nails will tend to jam when there are only a few nails left (keep the feeder full). Good luck and let us know what you find that works best.
Jun 15, 2011 | Porter Cable FR350A Factory Reconditioned...
My nail gun was working fine and suddenly stopped. I checked to see if a nail had jammed or if the fuse had blown, the fuse was fine and i removed a nail from the shaft. When i tried to use it again it...
if this is a Bostich/Stanley nail gun that is a normal malfunction the best way to prevent this is to get a few drops of pneumatic oil in the upper portion of the nail tray, or some WD-40 and keep it lubricate after and before every use.
Apr 18, 2011 | Tools & Hardware - Others
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Tools & Hardware - Others Logo
56 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
