Question about Garden
How do i convert watts to amps? - Garden
  • 1,169 Answers
Wattage is Voltage times Current (amps) so IF you know the wattage and voltage then you simply divide wattage by the voltage.
Posted on Apr 05, 2015
I need to convert amps into watts
Watts = Amps x Volts
you can go to Google and just type
5 amps x 12 volts = watts and hit enter and you will get the answer.
or search Google for an Amp Volt converter like:
http://www.rapidtables.com/calc/electric/Amp_to_Watt_Calculator.htm
All the best to you.
Mar 09, 2015 | Banks Power Pack Pack System 49378 Ford...
Amps to watts calculator
You cannot convert from amps to watts.
The Ampere is a unit of current intensity while the watt is a unit of power.
They can be related through the Joule effect law in a resistor
A resistor of resistance R that carries a current intensity I dissipates a power P=R*I^2=(R*I)*I=U*I where U is the potential difference across the resistor.
1 Watt = 1 Ohm *(1 A)^2
1 Watt = 1 Volt* 1 Ampere
Mar 25, 2014 | Office Equipment & Supplies
What can i run with a 500 watt stanley converter
Assuming the output is 120VAC, you can only run items pulling about 4 amps. If the voltage output is 220 VAC, you can only run items pulling about 2.25 amps. Read the labels on the devices you want to use, they should list either watts or amps used.
To convert amps to watts: Current times voltage
To convert watts to amps: Watts divided by voltage
Dec 04, 2012 | Electronics - Others
How many HP is 7 amps?
You can't convert amps to HP because amps are unit for electric current and HP is unit for power. You could calculate power if you also knew voltage because power=voltage*electric current for DC circuits. You would then get result in watts, and you could use formula 1 watt=0.00134102209 HP
For more information about electric power in DC circuits click here. You can also use this online calculator to convert watts to HP and vice versa.
I hope I helped you, if you have more questions feel free to ask in the comments :)
Sep 09, 2011 | Office Equipment & Supplies
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I am trying to find out the watts for a Frigidaire Side By Side Model #GLRS234ZA. It is going to be used in Chile, South America and I would like to know how to make it work there. Thank you.
on the model # plate it will have the serial # also what type freon is used in it, and it will have the amperage or amps. when normally working for example let's say is 3.5 amps, this will need to be converted to watts and you can google for that formula to convert amps to watts.
Nov 08, 2010 | Frigidaire GLRS234ZA Side by Side...
I would like to know the ma watt a/c converter I
a 1500 watt inverter draws appx 100 amps from your battery,check with your dealer and see how big in amps your alternator is rated for,if its less than 160 amps you may run short in the summer with the a/c and lights on and discharge the battery or ruin the alternator
May 09, 2010 | 2005 Chevrolet Equinox
How many watts would you get from a generator rated at 11hp and 5.8 kva. thanks
kva = kilo-volt-amps
watts = volts x amps = va
Therefore, 5.8kva = 5800 watts
Mar 24, 2010 | Honda 3000 Watt Portable Generator
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
