Question about Measuring Tools & Sensors
Briggs and Stratton 24 hp twin intake melt - Measuring Tools & Sensors
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
  • 395 Answers
SOURCE: Briggs and Stratton Intek V
Misfiring could be caused by simple things like fouled or worn out sparkplugs or an ignition system that is slightly faulty or Fuel problems such as dirty or stale fuel or clogged filter causing a leam mixture. Some B & S motors have an switch that cuts the Ignition if the oil pressure or oil level is low.
Another cause could be the Valve clearances are out of adjustment.
Armed with your Engine Number, visit the B & S Website for comprehensive information and specifications as well as a good FAQ listing.
Posted on Sep 17, 2010
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Measuring Tools & Sensors Logo
97 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
