Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Battery is good. Won't power on. - Bushnell Tour V2 Pinseeker Laser Rangefinder
Blades won t engage on my ariens ezr1740 riding lawnmower. Motor runs good. Belts r good. What should I check
Check your battery is well charged. Also check that fuse is not blown in electric clutch circiut. Clutches take a good power supply to engage. Check water level in battery. Maybe have to charge battery with external charger on power point.
Jul 22, 2014 | Garden
My 91 Mercedes sel won't start. The battery is
check all wires to starter motor for bad earth.....make sure power reaching starter motor.....check starter motor isnt stuck
Feb 07, 2013 | Cars & Trucks
My laptop won't turn on. I tried taking out the battery, a different battery, a differnet power cord. It won't turn on. Is there a way to reset it?
Are there any lights or indications on the battery itself that might tell you if the battery is good? I had a laptop with a similar problem and it turned out to be both a bad battery and a bad "power brick". replacing both fixed my issues. Also, try holding the power cable at the point where it connects to the laptop and push to the left or right. A friend's laptop would only start if you held the power cable to the left. Otherwise, it sounds like a mother board issue. Sorry.
Oct 11, 2012 | Dell Inspiron 8600 Notebook
My hp pavillion laptop will not charge my battery . It won't even work without the battery but plugged in with power supply even though i know battery and power supply are sound.
It won't ever be a 'software' issue....it will be either a :
Adapter/Charger issue (Have it tested by local PC repair shop.)
if it is good, then it is the other prob. If it is not good, then buy a new one.
OR
Laptop power connector issue. (expensive repair.)
Sep 06, 2012 | Toshiba Satelitte M300 St3401 Core 2 Duo...
Battery completed drained, now won't start up even with A/C power
If it is not opening with AC power that is the not fault of battery instead of main chip on the motherboard, so you need to check it and take it a very good laptop technician.
Good Luck
Aug 21, 2012 | Medion MD 96340 PC Notebook
Won't start battery and starter are good
BATTERY SHOULD HAVE 12.6 VOLTS. IF BATTERY GOOD USE TEST LIGHT SEE IF POWER GOING TO STARTER. IF NO YOU HAVE BLOWN STARTER FUSE BAD RELAY FAULTY IGNITION SWITCH OR BAD BATTERY CABLES.IF POWER GOING TO STARTER THE STARTER SOLENOID FAULTY.COULD HAVE BAD CLUTCH START SWITCH ON MANUAL TRANSMISSION MODELS.
Sep 06, 2011 | 1998 Toyota Sienna
My Volvo s60 won't start replaced battery and starter and still won't start battery test fine what can I do I have good power throught out
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
Aug 28, 2011 | 2001 Volvo S60
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My samsung s5230 got tea spilt on it. won.t turn on.
Take the battery off. Leave the cover off. Put the phone in a bag of rice. Make sure it's completely surrounded by rice. Leave for at least a day. Two would be better. Clean the phone off, reinsert the battery, plug it in to power, and try it. If it still won't power on, getting it wet with the battery in has shorted out components and blown them. If it does work, all's well.
Jul 06, 2011 | Cell Phones
Battery shows 24.8 volts no power
Yes, your batteries are trashed. You need to replace them. Or take them off the chair and put them on a car charger,slow charge. They need to be up over 24VDC. If they fall under 24VDC the charger won`t recognize them and won`t charge.
Mar 30, 2009 | Golden Technologies Buzz Around 3 Wheel...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
787 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
