Question about Boating
My Boat will not start, just a momentary generator sound. I installed a new throttle cable and batteries, no change. Is there a reset or a circuit breaker to check? Any suggestions? Thanks, david
    Problem Solver:
  • 17 Answers
Need more info on the engine. If an inboard sounds like a bad battery, ground, or connections. If not that sounds like a bad starter drive. The starter would spin but not engage.
If it is an outboard the same would be true as above check battery and all connections. Look for green corrosion on all connections an clean as needed. Lubricate the starter drive with WD-40 if it does not engage the flywheel. That needs to be done regularly. Starter drive is on top of the starter where it engages the flywheel. Do not use oil on the starter drive as it is too heavy and the drive may not work.
Posted on Apr 20, 2015
    Champion:
  • 254 Answers
Sounds like your starter is spinning but not engaging. Low/bad battery, dirty cables. More info in engine would be helpful.
Posted on Apr 18, 2015
496ho motor in my laveycraft2750
It sounds like your timing is off. It should be advanced a bit.
Jul 09, 2014 | Boating
Burned cable under diode 2 socket at the engine compartment fuse box
For many modern computerized cars, there a reset after battery installation. Google for the trick for your particular model and year. Usually mode is to have headlights off, remove battery and wait five minutes before installing the new battery. If the wait is not done, one of the CANs may burn out. On my car, the windows and sun roof need to be opened and closed in a certain sequence. Check to see if the battery is fully charged, starter relay and, any melted insulation on any wires, fusible link okay? Otherwise it sounds like a profession service may be needed, esp. if it's a CAN problem. Test the 2 diodes to see if they are good. If not replace.
Nov 23, 2013 | 2001 Ford Focus
Dell Inspiron 530. At start up gives CMOS checksum error defaults loaded. Options press F1, F2 or F12 computer does not react. Has new CMOS battery. RAM OK. Did CMOS clear and password reset. What else can...
When a Power Supply is plugged into power, there is a constant 5 Volts present. The 5 Volt Standby Power.
You press the Power On button.
This in turn presses against the Power On switch, located inside it's plastic assembly.
The Power On switch is a Momentary Contact Switch.
Temporary closing it activates the Soft Power On circuit.
A 5 Volt circuit that utilizes the 5 Volt Standby Power.
The Soft Power On circuit 'excites' the Power Supply, and turns it on.
(Sounds like a seedy novel)
The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
A checksum is computed as an error-detecting code, to protect the BIOS settings stored in CMOS.
Each time the computer is turned on, this number is re-computed; and checked against stored values.
If they do not match an error message is generated, to tell you the CMOS memory contents may have been corrupted; and therefore some settings may be wrong.
Your BIOS assumed the settings were incorrect, and loaded BIOS default settings; stored in BIOS.
(Default = factory settings)
CMOS Checksum Error Defaults - Loaded
New battery? Nope didn't help.
Clear CMOS, and password reset? Nope didn't help.
Leaves Virus as the problem, or hardware component/s on motherboard; are bad.
My thoughts?
Bad motherboard.
("BAD motherboard. NO,...........you know you have been bad,....don't give me that look. You're a bad motherboard."
Lol!)
That's my diagnosis.
(Unless you put the CMOS battery in upside down.
+ goes UP)
Regards,
joecoolvette
Mar 17, 2013 | Dell Computers & Internet
I just put a brand new battey in my 95 katana but it still.loses power and dies and wont start
Sounds like your regulator/rectifier has failed. This is a fairly common fault on GS and GSX models, particularly the smaller capacity (below 750cc) models. Did the oil level fall below minimum at any time, because this can cause the generator on some models to overheat, causing a power surge which can burn out the regulator. Get the generator checked and fit a new regulator/rectifier.
Oct 10, 2012 | Suzuki GSX 600 F (Katana Motorcycles
1992 K1500, code 22, clicking noise from throttle body, will not accelerate properly, changed TPS with no change
OBD Code 22 - Throttle Position Sensor Error (Signal Low)
The Throttle Position sensor signals the Engine Control Module as to the current position of the engine throttle valve. The current throttle valve opening is based on the driver's input from the gas pedal. The ECM uses the information from this sensor to help calculate fuel delivery and spark timing.
Symptoms:
* Extended cranking, possible no-start condition
* Lack of power
* Erratic transmission operation
Common Problems:
* A failed Throttle Position Sensor (TPS) would be the most common causes for code 22
* Testing the TPS circuit would involve checking voltage and ground from the ECM-5v is the normal reading between the ECM reference circuit and the ECM ground circuit at the TPS connector. Checking the TPS signal circuit to the ECM would involve monitoring the TPS signal on a scan tool while jumping the 5v reference and the signal circuits. The TPS reading should go from high when the circuit is "jumpered" to low when the jumper is removed.
Keep us updated.
May 04, 2011 | Chevrolet 1500 Cars & Trucks
Boat engine will not start even with new battery. The engine is a Perkins 4236 I have just had the starter motor reconed and new pos and neg leads put in,but the starter motor seems to be under strain when...
This may sound over simplified but..... old battery cables corrode onboth ends so you have less amperage carried by the cables. (i.e. fewer strands of copper trying to carry more amperage than they are capable of. The next time you do a start cycle place your hands on the battery terminals one at a time and check to see if they are HOT to the touch. Also do the same thing for the chassis ground and the terminal lug at the starter. ANY hot terminal is a sign the cable has broke down either from age/vibration wear or corrosion. If you suspect the battery cables are bad get a VERY GOOD set of jumper cables (2 sets connected together if necessary) and do a direct from the battery to the starter connection. This is loads of amperage so be very careful and DO NOT do this alone. But, if the starter spins faster you have battery cable problems.
IF you have an external to the starter relay that too can cause the problem due to worn / defective contacts.
I will watch for any responses.
Thanks for using FixYa.
Kelly
Jun 16, 2010 | Pramac GBW30P Encl Diesel Genset w/Perkins...
Really need some help changeing alt on 2000 intrepid
  1. Disconnect negative battery cable.
  2. Raise and support vehicle.
  3. Remove lower plastic splash shield.
  4. Remove transmission cooler and reposition cooler out of the way.
  5. Remove lower radiator cross member support and position a jack stand under radiator for support.
  6. Loosen adjusting T-bolt, but do not remove.
  7. Loosen pivot bolt, but do not remove.
  8. Remove the generator drive belt.
  9. Disconnect the generator field circuit plug.
  10. Remove the B+ terminal nut and wire.
  11. Remove pivot bolt, being careful not to lose spacer.
  12. Remove generator.
INSTALLATION
  1. Install generator.
  2. Install pivot bolt, leave loose.
  3. Connect the generator field circuit plug.
  4. Install the B+ terminal nut and wire.
  5. Install the generator drive belt.
  6. Adjusting T-bolt and tighten belt.
  7. Remove jack stand from under radiator and install lower radiator cross member support.
  8. Reposition transmission cooler and tighten fasteners.
  9. Install lower plastic splash shield.
  10. Lower vehicle.
  11. Connect negative battery cable.
Jan 13, 2010 | 2000 Dodge Intrepid
Brand new 350 motor rev's fine but will not pass 2000 rpm in water boat is a 23' 1988 starcraft
We are going to assume there is no Rev limiter in the ignition circuit.
Disconnect the throttle, move the throttle lever by hand and see what RPM you pull. It should be able to go higher than when you had a load on it. Check your throttle stops.
If you have a 4 barrel with a secondary, look at the mechanical linkage. If you have a vacuum operated secondary, see if you have any open vacuum ports.
If this is a vacuum secondary, there are springs you can buy to change when the pulldown occurs.
Check for a clogged gas filter, kinked hose, or hole in the gas line before the fuel pump.
If this new engine is running the same carb and ignition as the old motor, check your base timing and advance.
If you have not used this boat before the new engine was installed check your prop pitch and size. The prop is like changing gears, you need to adjust throttle stops so you do not over rev or under rev. Let us know what you found.
Sep 15, 2009 | Boating
2003 Toro 14-38Z will not come up to full power
Hey..my name is Keith..try disconnecting the throttle cable and moving the throttle on the carb with your fingers..and if it makes max power..then it has the wrong throttle cable on it..but if there is no change in power..then i would suspect the govener..if this dont help..please write back
Jul 06, 2009 | Garden
Electrical sytem dies then returns when cooled down
Ford has a technical service bulletin out that may fit your concern.
ISSUE:
The charging system indicator may illuminate or vehicle may not start. This may be caused by a discharged battery due to a poor electrical connection at the generator terminal.
2.0L
  1. Replace generator B+ cable with a new Cable (F5RZ-14300-FA).
  2. Replace the generator B+ terminal with a new Terminal (F3RZ-10329-AB).
  3. Install new B+ cable retaining nut and tighten to 10.6 ±1.6 N-m (8 ±1 lb-ft).
2.5L
  1. Replace generator B+ cable with new Cable (F5RZ-14300-EA).
  2. If the generator B+ terminal is damaged, replace the Generator (F6RZ-10346-BB).
Jan 31, 2009 | 1996 Ford Contour
Boating Logo
183 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
