Question about Pool & Spa
Hello I have the polaris 480 pool sweep. Does anyone know how to tighten the chain? My unit has a lot of slack and one wheel tends to come off track often.
    Top Expert:
  • Pool & Spa Master
  • 6,951 Answers
Usually wheels have adjustments
Posted on Apr 20, 2016
  • 4 Answers
SOURCE: Polaris 280 - tank track keeps coming off
I battled with the track falling off for over a season. The pool guys said they fixed it. Tried the previous solution to adjust middle wheel but no luck. My solution was to remove the left wheel and the tank (to get to the screws). The wheel mount allows for minor adjustment but it is also reversible. Turn the mount around and this will extend the wheel base much more. Mine ran for several hours after doing this and so far the track stays on.
Posted on May 10, 2009
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
  • 128 Answers
SOURCE: Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Posted on Aug 23, 2009
jharwell668
  • 640 Answers
SOURCE: 280 sweep hose does not sweep-drags behind unit
Make sure that the opening at the end of your pool cleaners sweep hose is not blocked by the sweep hose scrubber. If this does not work, you will need to adjust the sweep hose screw as mentioned above. The only thing that I would add about that is to make sure that you turn your booster pump off before you make adjustments. Hope this helps! I have a copy of the users manual for this model. Let me know if you need it and I can give it to you.
Posted on May 20, 2010
jharwell668
  • 640 Answers
SOURCE: Pool sweep wheels are not turning...
Problems with the sweep hose on these pools cleaners usually just means that you need to do some fine tuning. Start by trying to adjust the sweep hose adjustment screw. To adjust, turn off the booster pump and turn the screw clockwise to decrease motion and counterclockwise to increase. You might also need to replace one or both of your swivel ball bearings (part #D20).
Posted on Mar 30, 2011
How can I shorten the chain on a Polaris 3900 pool sweep
Curious to know why it needs shortening. The machine should have an automatic tensioner inside that keep the chain right. I am unaware of any way, or any need, to shorten the chain.
Get on YouTube or a Polaris site to see if all your internal parts are present and functioning correctly.
Mar 13, 2017 | Polaris Pool & Spa
Polaris 3900 Sport - wheels move very slowly. Booster pump and water pressure are fine. Seems that there is a problem with the chain. When manually moving the wheels, they don't move smoothly. I was...
take the body off after taking out of pool there should be a adjustment to tighten up the chain sometimes the hoses on the inside come off try these things
Sep 08, 2013 | Polaris 380 In Ground Pool Cleaner
Polaris 380 sweep hose isn't moving -- i have checked the sweep hose adjustment screw and it does't make a difference. the polaris unit is moving and vacuuming and there is water going through the sweep...
There are a few things to check with these pool cleaners. Make sure the opening at the end of the sweep hose is not blocked by the sweep hose scrubber. If you have any sweep hose weights, you might need to remove or adjust them.
Jan 10, 2011 | Polaris 380 In Ground Pool Cleaner
May 19, 2010 | Polaris 280 In - Ground Pool Cleaner with...
280 sweep hose does not sweep-drags behind unit-unit works fine-cleans pool
Apr 27, 2010 | Polaris 280 In - Ground Pool Cleaner with...
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Pool & Spa Logo
48 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
