Question about Haier Televison & Video
Haier LE50F2280 50-Inch 1080p 60Hz LED HDTV power on but the screen is black. I know is the main board is the main problem. I want to know is worth to replace it or buy the new TV? Thanks
    New Friend:
Hello mine is doing the same thing where is the main box at on them
Posted on Aug 24, 2016
4 Suggested Answers
  • 16 Answers
SOURCE: Sharp LC46SB54U 46-Inch 1080p LCD HDTV Shattered LCD Screen.
it would be very expensive for replacing the screen,even the dealer won't afford that.
Posted on Mar 31, 2009
  • 10 Answers
SOURCE: my jvc lcd shutt down every time and i dont know the rason
I can honestly say I have been quite happy with it and its performed pretty well with very few problems and is still going today.
First of all congratulations on getting so many years of heavy use (2002 - 2012) on your JVC VCR.
I have a HR-S3911U and a HR-S5912U from the same era and my 3911 has seen a million miles and both my units are still going strong. I did experience a similar problem with my HR-S3911U but instead of the eject function my problem was with a sticking guide-pin. I did a have similar ejection problem with one of my 1985 Super Beta Hi Fi machines. Really it sounds like the exact problem as you describe. What I did was I opened up the unit and watched carefully - it was just a sticking moving part. My JVC guide-pin problem was just sticking as well - after a gentle push into place the guide pin has not stuck since. I don't suggest using any grease unless you really have to. I suggest you open the unit - if you have a video camera video tape the ejecting and play back in slow mo to see if you can catch the problem. Sounds like a sticking moving part which can be common on any VCR.
..couple times its had issues with dirty heads as i would get a message appear on screen.
I'm very surprised that in the past you had "dirty heads" messages pop up on screen as I have never seen that message on my JVC machines and I do use them a lot and very rarely clean the heads. Proper tape storage is very important. Trying not to use the same tape over and over again also helps keeping the tape path reasonably clean.
I think it could benefit from the heads being cleaned. I don't even really know what are the heads. Is it that big round drum? One thing I did notice is that when I load a tape, it straight away wraps the tape around that drum and the drum spins away and just idles there constantly rubbing on the tape before i have even pressed play. I have left tapes in there for days and days, so I assume this cant be good having that thing spinning away on the tape for such a long time?. I am not sure if this is normal or not but I wont be leaving tapes inserted in the VCR long periods now.
The heads are tiny little things inside the big round drum. I will show you if you post a picture of your unit with the cover off.
The tape staying wrapped around the drum with the drum spinning is normal but the drum should stop spinning five minutes after you load the tape as long as you don't touch play, rec ,ff or rewind. This is called a "long pause" (the tention is a little eased and is not rubbing hard as a normal pause would) and the long pause is there so the unit will immediately start playing or recording if you push play or rec within 5 minutes of loading the tape. If the drum does not stop after 5 minutes of sitting idle then your VCR has a malfunction and you should not leave tapes in the machine idling.
I am concerned about your heads clogging up - that is not normal unless you don't take proper care of your tapes - is there very high humidity in your area? That could cause problems.
Sorry I posted this in a hurry but will go into more detail later if need be.
Porsche Parts.
Posted on May 27, 2012
  • 75017 Answers
SOURCE: Apex 24 in. LED 1080P 60Hz HDTV LE2412 Manual
Try this link to download it.
Posted on Jul 12, 2013
My OCosmo 47" LED TV will not turn on. I already replaced the power supply board, now what?
And all the Capps are down on the rest of the boards also it a switch mode power supply so make sure it's switching
Oct 07, 2016 | Ocosmo Ocoo 47-Inch 1080p 60Hz LED HDTV...
Seiki SE50FY10 has sound but no picture, flashlight test shows picture. Not sure which board to replace
Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
Why does it turn off after I turn It on?
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 31, 2016 | Philips 46PFL3908/F7 46-Inch 1080p 60Hz...
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV -- turning on and off, fix?
sad to inform you but we do not have any parts for anything here on FIXYA.COM .
Nov 05, 2015 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
I have sound and power is on, but a black screen?
Check for bad inverter board responsible for the back lighting so you can see pic.
Oct 20, 2015 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Se50fy10 backlight not working
This is an exact problem that I am facing with my Seiki 50" TV. From my research, here are the probable issues:
1. Main Board/T-Con Boards are fine
2. Power Board : MIP550D-5TB could be defective - most probably the culprit. There is a power test to try but w/o schematics, it is not possible to identify component
3. If Power Board replacement does not solve, it is the backlight LED strips that are defective - tought one to replace.
Will update this thread at a later date.
Sep 18, 2015 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
Our Haier 42HP25BAT Plasma TV made a loud pop sound and the picture went out but it has sound...will the replacement of the TV-5210-96 Digital Board solve the problem?
The TV need a thorugh check up, before doing any repair to it. Some repair works, can be done manually. It sounds that some electrolytic capacitor on the main power reguaator board has bursted out. Check the power regulator baord first. Digital baord faults are rare. In most cases, main power board might be replaced as card basis.
May 11, 2012 | Haier 55" Led 1080p 60hz - Haier
Televison & Video Logo
147 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
