Question about Garden
Mower Shaft tangled
My son was mowing the yard for the first time this season and ran over a length of metal wire along the edge of the street. It is now wrapped around the shaft of one of the blades. We've removed the deck and the affected blade, but the wire is tangled tightly up under the blade adapter--basically a big piece of metal at the end of the shaft axis that the blade attaches to with two screws. I'm not seeing anything in my manual about removing this. It seems like I might be able to do it by flipping the deck and trying to remove the belt wheel, but I don't want to go experimenting. The wire is fairly heavy and cannot be pulled free without access to this area, though.
  • 7 Answers
Did you try cutting the wire off
Posted on Apr 05, 2015
  • Christopher Appel
    Christopher Appel Apr 05, 2015
    Yes, but it's tough (like bailing wire) and has wound up around the shaft under the adapter. It will take hours of work to cut and yank all of it out.
    Top Expert:
  • Garden Master
  • 45,346 Answers
Get an angle grinder and a couple cutoff wheels for steel and cut the wire out and off quick and easy .
Posted on Apr 10, 2015
    Sergeant:
  • Garden Expert
  • 187 Answers
For an answer specific to your situation we need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one.
Sounds like you have John DeereGY20785 or GY20050. In the attached picture you can see the spindle off the deck with the top pulley and the blade removed.
  1. Take the blade off.
  2. Take the Nut and pulley off the top.
  3. Take the 4 bolts out and the spindle will drop out of the deck.
  4. Support the spindle in a vise.
  5. Put the top nut back on loosely
  6. Firmly strike the top nut with a rubber mallet, down into the spindle. (the manuals say use a rubber mallet. I just carefully tap it out with a regular hammer.)
  7. Spin the nut up a couple turns and lightly tap some more.
The shaft will come loose and you will be able to take the top nut off completely and lightly tap the shaft out the bottom.
Posted on Apr 06, 2015
Testimonial: "Thanks, the diagram and explanation helped me loosen the shaft enough to get the wire out. Much obliged!"
  • 3 more comments
  • Kprime
    Kprime Apr 06, 2015
    Once you tap the shaft loose all the components will separate. Put them back together in order, support the spindle upside down over the vise. Allow the shaft to mover freely, using the rubber mallet drive the shaft back into the spindle and the whole unit will tighten back up.
  • Kprime
    Kprime Apr 06, 2015
    If the top pulley has never been off, it might be a bit stubborn. You can use a puller to remove it. I just grab the sides of the wheel with both hands and rock it up and down till it pops loose.
  • Kprime
    Kprime Apr 06, 2015
    If you want to replace the bearings you can get them on amazon, Peer 6203-RS
  • Kprime
    Kprime Apr 10, 2015
    you are welcome. BTW the blade nut torque is 55-65 lb-ft.
  • Kprime
    Kprime Apr 10, 2015
    The top nut of the spindle, with the pulley, torque is 105 lb-ft. the 4 10mm bolts that hold it in are torqued to 216 lb-in (24 Nm)
  • 1,169 Answers
Chris. sometimes takes doing that is not in the owners manual. If you feel like you can do it then have at it. Just makes notes or take pictures as you so you can a reference points to go by when putting it back together.
  • 3 more comments
  • Christopher Appel
    Christopher Appel Apr 06, 2015
    Can't even do that. The cap screws on the belt shield are larger than 3/8 but smaller than 7/16 and between a 10mm and 11mm metric wrench. Since that is user serviceable as part of replacing the belt drive, I'm not sure why standard tools can't remove it.
  • Eugene Rounds Apr 06, 2015
    Chris, Could you post the make and model so I can look-up IPL to see what is going on here with the parts?
  • Kprime
    Kprime Apr 06, 2015
    The cap screws holding the Shield, and the Spindle are both 10mm. They are in fact the same screws.
  • Kprime
    Kprime Apr 06, 2015
    I should say they are "identical" screws, not the same screws.
  • Christopher Appel
    Christopher Appel Apr 10, 2015
    Yes, they were 10mm, just not the 10mm Walmart sold me, lol. I dug through another wrench set and got them off, thanks.
It ran mowed a hard lawn of grass now it wont start to moe soft blade grass
while unplugged try turning the blade by hand . it should turn easily . then check to see if grass or string has gotten wound around the shaft.
Oct 17, 2015 | Greenworks 20" 12 Amp 3-in-1 Electric...
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Jul 29, 2010 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Bent Shaft???
Check that the blade securing bolt is secure. While you're there, have somone SLOWLY pull the starter rope. It will be obvious if anything is bent to the extent you describe.
If this machine has a blade clutch, engage blades while you do the pull test (DISCONNECT PLUG WIRE!!!!)
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower won't start
sound like timing is off sherd a key in flywheel
take cover off where you pull the rope and then
take off nut off flywheel its going to be tight and hard to get off but can be done take a screwdriver to hold flywheel ones the nut off look around shaft see if flywheel key is sherd
or pry off flywheel be carefull dont damage anything if sherd replace key
Jul 21, 2009 | Garden
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
When you turn your mower deck on it comes on and
Very possibly an open or a short in the electrical circuit that controls the power take-off. Inspect the line connecting the switch that engages the deck all along it's length to see if it's frayed somewhere. If the bare wire is contacting metal, you have a short. Very possibly one end is somewhat loose giving you an open circuit. Take the ends off, clean and reinstall tightly.
Jun 15, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
May 12, 2009 | Craftsman Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
