Question about Stihl Garden
How do I repair a Stihl FS90R weedeater handle that sticks?
    New Friend:
  • 4 Answers
If lubing the hole handle an cord with wd40 it could be a jam somewhere in the handle. good luck my friend
Posted on Apr 05, 2015
3 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: no power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Posted on Aug 04, 2009
What is Wrong With a Stihl FS90R Trimmer When The Primer Bulb Won't Fully Fill After Priming?
1) check valves inside the primer plate is sticking
2) fuel pump diaphragm is varnished and flaps are sticking to the body of the carb
3) the cost of parts and time spent are more than a new carb
4) new carbs are updated versions and have updated ethanol resistant components
** suggest a new carb, it will solve several performance issues
Feb 19, 2017 | Stihl Garden
My stihl fs90r motor run faster than the part with the weef eater line
sounds like the shaft isn't engaged properly at the engine end or the cutter head. or the inner shaft could be damaged, but most likely it will be that the head isn't on properly
Aug 24, 2015 | Stihl Garden
How do i replace tank fuel filter on a stihl model fs90r
The filter is hanging on a flexible fuel line in the tank. make a hook on the end of a piece of wire and go fishing.
Jun 01, 2015 | Stihl Garden
Stihl FS90R weedeater trigger sticks
Replace the throttle cable they bad to fray at carburetor end.
Apr 05, 2015 | Stihl Garden
How to repair Stihl 590R weedeater handle that sticks when you squeeze it?
you could have a frayed throttle cable or the screws in the handle halves are too tight.
http://www.mediafire.com/download/515xc50iny23o7k
Garden Logo
93 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
