Question about Freezers
How many watts does a old gibson 21.6 cu ft freezer use
  • 3,289 Answers
Tractorman44 is pretty close on his calculation suggestion - and may be sufficient for your needs; however, that is for calculating wattage in a DC circuit (or a purely resistive AC circuit such as a toaster or incandescent light bulb). AC power (wattage) calculations are much more involved and require knowing power factor (the amount of inductive reactance & capacitive reactance) in circuit. The only way to know for sure the amount of wattage used is from the manufacturer specs. It may be expressed as VA (volt amps) or a KVA (kilo volt amps) rating - which is as close to "wattage" in AC circuit as you're going to get.
Posted on Apr 08, 2015
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Check the nametag on the fridge and take note of the total amperage draw of the unit. That that reading, and multiply it by 120 volts and the resultant answer will the the total wattage of the unit... If you want to get it precise, measure the applied voltage at the receptacle where it is plugged in. Your 120 volt circuit may really be supplying 125 volts or more and that will effect the calculation....though minimally.
Testimonial: "there are no tags w/ amps or wattage that is why i asked"
  • tractorman44
    tractorman44 Apr 12, 2015
    Sorry Joyce, I wasn't aware that there was no tag with any information available to you. Another simple suggestion would be to ask a maintenance man at your place of employment if he has a tool called a "Clamp-on ammeter" and its companion accessory plug in for measuring the current in a residential circuit. The accessory is merely a split receptacle that you plug the appliance in to and this device is plugged into the wall outlet. The clamp-on ammeter then clips into the split opening in the accessory and the ammeter will then give you the total amp draw of the appliance. Take that amp draw and multiply it by the 120 volts applied voltage and you will get the total wattage of the appliance. Of course the freezer has to be running in order to read its amperage. I know this will probably not be possible for you to accomplish, but it would be a very simple chore for a technician.
Freezer light bottom not working,bulb good
Warranty time, call maytag, most fridge come with 1 year warranty.
Oct 27, 2013 | Maytag Ice2O MFX2571XE 25 cu. ft. French...
Looking for the start up surge for my kenmore freezer 253. I would like to purchase a generator and want to make sure this freezer would operate.
At the peak power usage time..compressor start up it may reack 11 amps..when calulating that it is a max of 1300 watts..so a generator of 1500 or more should work fine
When running after start up is usually about 500 watts
Gene
Aug 26, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My upright Gibson is about 28 years old (I bought it new), and has been a wonderful work horse for all that time. I thaw it slowly once a year, taking care to use no sharp objects, dry it completely, and...
youve guessed it its like you and me its getting ready to retire...
nearly time for a new unit.and you will be suprised to learn the new ones wont last as long as yours,but it will be cheaper to run.
Sep 07, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Freezer
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezers Logo
217 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
