Question about Stihl Garden
How to repair Stihl 590R weedeater handle that sticks when you squeeze it?
  • Stihl Master
  • 1,807 Answers
You could have a frayed throttle cable or the screws in the handle halves are too tight.
http://www.mediafire.com/download/515xc50iny23o7k
Posted on Feb 27, 2016
4 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: Stihl weedeater starts but won't run at high speed
This sounds like a timing problem.
It is too far retarded, and needs advancing a couple of thou.
There you go:)
Posted on Jul 25, 2009
moretons
  • 155 Answers
SOURCE: no power fs66 stihl weedeater
Hi When you cleaned the muffler out did you also clean the carbon out of the port on the cylinder as this can be blocked as well. Also you will have to retune the carby, There should be 2 screws 1 for low speed marked l on the carby body and 1 marked h for high speed to start with they should be set at 1 & 1/2 turns out from closed the low speed you set at an idle and the high speed you set at full throttle. Hope this helps.
Posted on Aug 04, 2009
rxrdemons2t
  • 4 Answers
SOURCE: How do I repair a Stihl FS90R weedeater handle that sticks?
if lubing the hole handle an cord with wd40 it could be a jam somewhere in the handle. good luck my friend
Posted on Apr 05, 2015
Parts and repair manual for a Stihl FS45 weedeater
contact your local dealer . perhaps they can assist you .
Sep 23, 2016 | Stihl Garden
Stihl FS90R weedeater trigger sticks
Replace the throttle cable they bad to fray at carburetor end.
Apr 05, 2015 | Stihl Garden
Stihl fs44 weedeater wont fire
Do you have compression, a good spark and is fuel going into the cylinder.? Working on a solution.
Jul 27, 2012 | Stihl Garden
Stihl sf44 weedeater wont fire
more info please? does it now have a spark and good compression?
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
How to get the head off of a Stihl weedeater. Model FS 45
There is a hole beside the angle gearbox, stick an awl or small screwdriver into it & turn the head until it 'locks'. Then rotate the head clockwise until it comes off.
Jul 29, 2010 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
