Question about Borghese Curaforte Brightening Moisture Intensifier
I purchased this product and it s defective.
I purchased this product and it is defective. It is 3/4 empty, chunky, thick and the pump stem is missing.I would like a refund.Thank you, Kinsey Kimmer
  • 7 Answers
Take it back to store or wherever w/ receipt or proof of purchase
Posted on Apr 05, 2015
How can I substitute one knitting yarn for another?
don't know the type of wool you are speaking of, bu you need to identify what yarn type it is, ie double knit, 3 ply, chunky, etc.... and then you can just purchase wool that has the same ply and it should knit up the same as the Rico -just checked Rico its a super chunky its thicker than chunky which is 12-16 ply, so very thick. Ask for a wool that knits up on number 10 needles and is close to roving
Oct 29, 2014 | Sewing Machines
What causes brown gooey ring around Dream Maker Eclipse spa and how do i prevent it
try non chlorine shock to shock it sounds like you used a chlorine product with it which will cause a gooey mess if it doesnt go away try to drain clean up everything including the filters or by new then try to use bromine that is more stabile in a spa
Aug 29, 2014 | Pool & Spa
MY SCOTSMAN ICE MACHINE IS MAKING ICE, BUT ITS TOO HARD AND CHUNKY HOW CAN I FIX THE PROBLEM
First is the ice to thick coming off of the evaporator plate? If so then you need to adjust the ice thickness probe located at the top of the evaporator plate it is white with a 1/4" screw going through it, turn if left an 1/8" at a time let it make ice and check each batch. Now for chunky ice is it melted together? If so then make sure the machine is not dumping water into the bin during harvest if it is then check the dump valve to make sure it is opening during harvest cycle.
Oct 31, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Siphoning gas
The fuel tanks have protective baffles in the fill stem and they block hoses from entering the tank.
There is an easy way to remove fuel. Two things you will need to do are Look up the fuel pump RELAY wiring in the Powerbox under the hood and buy a tire valve removal cap. Some tire stem caps made of metal have removal tools incorporated in the stem cap, inexpensive, Walmart or Kmart.
Why do you need a tire valve stem cap? To remove the stem valve in the fuel rail test port on the engine. Once this is removed you have an opening for fuel to come out. Remove the valve and slide a rubber hose over the stem and clamp it down. Around a 1/4 inch or 3/8 inch internal diameter hose, long enough to reach an empty gas can. Now you are ready to pump.
To pump, remove your fuel pump Relay. Look at your obtained diagrams of the Fuel pump relay Layout. Jump the 2 terminals. Maybe 27 and 34, Look for Yourself as Layouts differ. The fuel pump will pump when jumped.
I removed 17 gallons in about 15 Minutes with a blocked pump. Do this on a COLD engine. Outside, well ventilated. It works.
Suggest topics like-"Fuelpump Relay Bypass", "2000 Lincoln Town car Powerbox Layout". Or See Autozone Help section on Web after registering your car.
Tire stem caps will cost about $3 for 4 pack, fuel hose about $7 for enough. small clamp $?.
Jul 04, 2013 | 2000 Lincoln Town Car
Have a 2001 fiat punto..was running then just cut out...got spark no fuel pressure ...have located the fuel pump....4 wires going to pump...on 1 of the wires on ignition its 12 volts but when you crank it...
Have you had the fuel pump output pressure checked....Sounds as if it could be defective.....Pressure should be above 3 .6 bar Or maybe check your battery condition, that may be the problem, but more likely the pump....
Regards Johngee10
Oct 29, 2010 | Fiat 500 Cars & Trucks
Under sink tank on older water filter onlyy produces 2 qt at one time. it use produce 1 gal. we have lime iron promblem water 3 flter culligun system under sink water filer system over20 yr old filters...
I am assuming based on your description that the system you have is a reverse osmosis system. If this is true, you most likely need to recharge the air pressure in your RO storage tank. I have included step-by-step instructions below. If you find that your tank is not holding air or the tank will not empty completely, the bladder inside the tank may be broken and the tank will need to be replaced. I have included a link to our selection of RO tanks as well. To recharge the tank you will need a bicycle tire pump and a tire gauge that will be capable of reading below 10 psi. If you don’t have one that reads in single psi increments, then a meter that starts at 5 psi will work.
http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
1) Close the cold water feed valve (if you can’t locate this on your system, you may be able to turn off the cold water to your sink)
2) With the RO tank valve on, locate the valve stem on the bottom or side of the tank. (this will look like the air stem on a bicycle or car tire)
3) Remove the stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave the RO
faucet open throughout the entire procedure)
5) If the current tank pressure doesn’t empty the tank, apply tire pump to valve stem
and pump a few times. Flow will increase and then gradually decrease as
pressure equalizes. Do not overcharge the bladder during this procedure.
6) Repeat step #4 and #5 until tank is completely empty. (Tank is empty when additional
pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5
& 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem
10) Open cold water feed valve.
11) The water is useable immediately; however, tank will take a few hours to completely fill.
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Jul 17, 2009 | Culligan Tools & Hardware - Others
I have a ge reverse osmosis filtration system and recently lost pressure and tank capacity. I have only had the system about a month and my water has been tested fine. I did leave town for 10 days, could...
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Apr 27, 2009 | General Electric Profile Smartwater Ultra...
Have a kent r/o system dont know how to hook it up is there any way someone can help
Necessary Supplies:
3) Remove stem cap.
procedure.
Apr 13, 2009 | Culligan Under Sink Water Filter
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
To recharge RO System Tank:
3) Remove stem cap.
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
Mar 19, 2009 | Culligan Under Sink Water Filter
Printer will not print.
http://www.fixya.com/support/p169991-brother_mfc_420cn_all_in_one_inkjet See if any of these solutions help
May 17, 2007 | Brother MFC 420CN All-In-One InkJet...
Borghese Curaforte Brightening Moisture Intensifier Logo
47 people viewed this question
Top Borghese Health & Beauty Experts
Robin Hill
Robin Hill
jeff tilburn
jeff tilburn
Are you a Borghese Health and Beauty Expert? Answer questions, earn points and help others
