Question about Welding Tools
Sears stick welder mod. #113.20245 is this an A/C-D/C welder ? it has a and b for pos. side trying to determine if it can burn cast metal rods for engine repair
  • 5 Answers
SOURCE: I have a Sears wire
The most likely cause of a burned up motor is jammed up wire or wire tention too tight. You can find the rectifier in the manual that came with it. If the rectifier is bad a simple test (fluke meter)would tell .
Posted on Apr 28, 2009
emissionwiz
  • 76691 Answers
SOURCE: Based on detail can you better explain what is wrong with my car
any well established trans shop, the VW shop will most likely charge for the road test, the trans shop won't
Posted on May 02, 2009
  • 19 Answers
SOURCE: Inverter stick welder welding rod sputters and sticks
It sounds like the rod that you're using is too big. If it is a 110 volt machine, and you're using a 1/8 rod...Then the rod is too big. Try a 3/32 rod.
Posted on Aug 06, 2009
co7196
  • 3433 Answers
SOURCE: welder loses arc while welding any rod bigger than
Amps too low
Posted on Nov 12, 2009
SOURCE: sears craftsmen welder model # 934.20175
email me for a copy, $3.00 for copying and postage
vstenzi@ptd.net
Posted on Dec 19, 2010
1. wont charge battery. 2. strikes ark goes to high idle but won't give hot ark and burn in and is sticking to metal. it acts like it is going to high idle but staying at low idle at the arc. any ideas?
If your battery is in good condition (check this one first, take it to your nearest autozone they'd do it for free) then you need to replace the voltage regulator, this one is located on the back of the unit under the back cover of the main engine, it looks like a black rectangle with two cables. For teh second problem, check your fine voltage button and increase it as needed until the rod does not stick to the metal, but not higher enough to pierce or burn thru it.
Dec 23, 2010 | Eagle 10000 W Portable Generator
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
I dont know what kind of metals this wire type can do, it says fire power 1440 u235 flux wire, but not sure what kinds of aluminums or steels it can weld. Im a certifed MIG aluminum welder, but this is a...
Usually a flux core only welds steel. It is a higher penetration weld than a MIG. Usually it acts similar to 6011 rods in SMA (Shielded Metal Arc) welding -- a.k.a. stick welding -- if you're familiar with that. I don't believe there is such a thing as flux wire for aluminum. There may be stainless wire for it, but I've never seen it. It probably could also be used for building up cast iron and cast steel, but nothing structural. I have a Chicago Electric one and I love it -- simple and it penetrates hard. My 90 amp will weld to 3/8" without breaking a sweat and if I baby it will go to 1/2" or better. It is difficult to go much lower than 12 or 14 gauge though due to the high penetration.
Nov 28, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Have a 120 volt 70 amp stick welder what gauge or stick type do i use
1/16th stick to 3/32nd.
3/32nd being the maximum. Don't use 3/32 for an extended period of time, or you can burn up that welder. (Even if it has a fan. If it doesn't have a fan built-in, I invite you to put a house box fan, close to the ventilation slots for the welder)
I would also recommend using 6011 rod. It's a mild steel rod, and is excellent to begin with. Usually used for filling, and medium strength situations. It does splatter, be aware of that.
Not trying to give you a tutorial on beginning welding, but would like to offer some tips:
1.Make sure the ground clamp has a good, clean surface it's clamped to. If not, it will be very hard to get the rod started, and also to keep it going. (Makes bad welds too)
2.Start with a B U T T weld. (Had to type it that way do to censorship of certain words)
That's laying two pieces of metal next to each other, and laying a bead in-between them. Easiest thing to start with. Go to corner welds next, (Two pieces together at a 90 degree angle), then try Uphill welds.
3.Shield flipped up on helmet, welder on. Lay the rod past the area you are going to start on. Past the metal edge. Lay the ->flux coating of the rod on the edge of the metal piece. The tip of the rod is past the metal edge by at least two inches.
This way you are lined up to begin the weld. Then flip your shield down, draw the rod back, until the tip of the rod touches the metal. Once the arc starts, lift the rod up a little to get the correct height, and keep that arc going.
4.Watch the PUDDLE, not the arc! You are watching the melted metal in front of the arc. You need to see how that puddle is doing, in order to compensate by bringing the rod closer, or further away.
5.Use a Zig-Zag pattern to begin with. Keep the Zig-Zag close to each other, until you are comfortable enough to make a longer pattern. Watch the penetration. Good penetration is the key, not a pretty weld.
6.Use the proper safety equipment. If the welding helmet lens has a tiny little scratch, you will burn your eyes. NO fun, believe me!
You won't know it until you wake up the next day with your eyes swelled shut!
Cover your arms, and use welding gloves. Welders give can give you a radiation burn, worse than a bad sunburn. NEVER just start welding a little with No welding helmet. Welding goggles are for the birds, or Acetylene welding!
Be safe, have fun welding!
Sep 02, 2009 | Welding Tools
My lincoln welder will not burn into the metal ,i don't think it's getting hot enough.
Are you holding the metel at the right angle? and the right distance? if you force the rod into the metal does it make a pool? or does it look like the het is dieing out and is laying molten metal on the top of the metal? Let me know and I will see if I can help. Need more information to help you.
Avid101
Aug 28, 2009 | Welding Tools
Jul 14, 2009 | Welding Tools
Welding bearing girdle for Hobart A200?
yes the cast can be welded(brazed). if you are able to weld this yourself, just remember before you can weld it, you have to heat it till it is cherry red then you can weld the piece. if your not qualified to weld it you can usually find a portable welding company to do this for you. hope this helps you please rate the solution...thanks
Sep 18, 2008 | Hobart A200 Stand Mixer
Welding Tools Logo
141 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
