Question about Inverter Electronics - Others
Fuse keeps blowing in 2000 watt power inverter
brainyass
  • 242 Answers
SOURCE: power inverter
Most likely a fuse. Check for a fuse on the inverter itself or one inline with the plug. Usually you can screw off the tip of the plug and replace the fuse inside.
Posted on Oct 24, 2008
SOURCE: 2000 watt inverter blows 60 amp fuse under load
I have a background in electronics so i hope i can help. Now after reading this i have the feeling this item does not put out 2000 watts cause if that were the case it should draw somewhere near 147amps. This is because to find out amps you need to take the 2000 watts and divide it by 13.6 volts (assuming what the vehicle runs at) that gives you amps. watts/volts=amps.
Posted on Apr 02, 2009
al_kupchella
  • 843 Answers
SOURCE: Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
Posted on May 20, 2010
  • 4 Answers
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Posted on Aug 24, 2010
SOURCE: Cant find the fuse on a black and decker 400 watt power inverter
I've had this inverter for about two years now, bought it for a cross country road trip to power my laptop and a couple of other things. I've pretty much liked it. Yes, the fan is a little noisey, yes, you have to use the provided battery clips for heavy loads. But it powers my Dell Inspiron 8500 laptop just fine (and its an old powerhog).
Recently a I let a friend use it with his inflatable mattress air pump during a camping trip.
What I didn't know is his pump has insane wattage, and it fried/bricked the inverter instantly.
Agh! I thought it was a goner, but took the time to look inside the unit. (Which is a solid and sturdy metal case, not plastic as another reviewer indicated). I was thrilled to discover there were some internal fuses. And while the fuses are soldered to the circuit board, if you've done any soldering at all they really are a snap to replace.
If you remove the four screws that hold the end cover plate on the side with the fan. You can remove the end plate and have just about a half inch or so of clearance. The entire lower circuit board will then slide out with firm pressure about an inch and a half (don't try and go any further, components on the other side prevent it).
On the right side (positive/red terminal side), you will see two 25 amp mini-fuses that are directly soldered to the circuit board. If these are blown (you can see through the semi-transparent sides if they still connect), that is most likely your problem. They are easily available from most auto and big department stores (Walmart, Target, etc) in their automotive sections.
I used a 40 watt soldering iron (30 watt should work fine), and applied it to the bottom of the circuit board where the fuse legs poke out the bottom. Using a pair of pliers, I applied a firm steady pressure to the fuse, pulling up, while applying the soldering iron to each of the legs (alternately) of the fuse. The solder melted, and I was able to work the fuse out in a few seconds. I did this for both fuses.
The replacement fuses cost all of $2. I dipped the new fuse legs in flux, then put them in the place of the old fuses. Again I heated the circuit board solder from below, and pushed the new fuse in place. Repeat with the second fuse until it is in place. Flip the board over and add some more new solder until it is firmly in place. Put it back together, and you are back in business! And for a whole lot less than a new inverter.
I've got pics of this process if anyone would like them. Good luck, and happy inverting.
Posted on Sep 21, 2010
100 watt inverter blowout new fuse and keeps on blowing it out does it still work
Fuses blow because of excess current flow so check for shorted wiring or correct connection in the plug. Are you connected to something that is drawing more than 95 watts as that will overload the unit and blow fuses.
Feb 11, 2013 | Black & Decker 100 Watt Inverter...
Outlet fuses keep blowing with inverter use
it could have a fault and thats why it's blowing the fuse, inverters can wear out and the parts may need replacing the capacitors the voltage regulator chips all these parts have to be taken into account, this parts don't last for ever they need replacing. capacitors can last upwards of 12000 hours but electric jolt and what you are use to be powered adds more drain on the electronics most inverters you can get at most 5 years out of them but it really depends on what you use on them, and if you useing it to its max or near max all the time it will wear out, then blow fuse
Jun 21, 2017 | 2000 Dodge Grand Caravan
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
IT KEEPS BLOWING CAR FUSES
Power inverters can do this if they are internally shorted or they are being over loaded. If you are just using it to charge a phone or a computer it should not be over loaded. Now if you are charging a computer and running a small cooler at the same time, that may be real close to max which may blow a fuse. Have you tried hooking it straight to the battery to see if it will run what ever you are running. It has it's own fuse so if it has an internal short it will blow that fuse. It if works hooked to the battery and is just blowing the cig lighter or acc. fuse it can be a weak socket. If the socket is hot it may have a loose wire on the back side causing low voltage which can blow a fuse. So hook it to the battery direct, if it works ok there, reconnect it to your acc port and if it is getting hot it may be the weak socket. If it will not run hooked to the battery, it has an internal short and it would be better to buy new than try and fix. Sorry.
Mar 22, 2011 | Vector VEC 024 400-Watt Power Inverter...
My name is Gena. The VEC024B that is being used by our field technicians are having problems with the fuse blowing in their work vans. Their vans are equipped with laptops.
Hi Gena, the inverter is a 400 watt unit. This is not a rating for a continuous load. You do not mention which fuse is blowing. This could be the fuse in the inverter or the cigarette lighter (power source) fuse. In either case, a fuse blowing could be a short circuit, something in the inverter shorted, or too much load. I am going to look at the too much load side of things. Not knowing how many laptops are being used, with the inverter if you have a 20 amp fuse in the cig lighter, this will allow you 20 amps X 12 volts = 240 watts. I would not run the inverter over 240 watts because of overheating issues. So, 240 watts will run 3 laptops. Just the laptops. Most laptops draw around 70 watts. check your power supplies on them to find their rating. If you exceed the 240 watts by combining the ratings, then you can expect trouble with your inverter. It will give 400 watts, but this is a temporary condition only. Another inverter will be needed or a larger one installed and it being connected directly to the battery (with a fuse of sufficient size installed). You could also (let us say there are 6 computers) charge and run 3, and the other 3 are running on their batteries. After an hour, switch so that the 3 running on batteries now are charging as well as running. The other 3 are now charging.
I hope this helps. If you have any other questions please provide additional information. Such as the size and location of the fuse blowing. The laptop power supply ratings.
thank you
Oct 15, 2010 | Vector VEC024B MAXX SST Power Inverter
My 400 watt inverter will not charge my laptop the fuse keeps blowing?
Your laptop PS has big condensers in the input. Even supplied by mains through 6A quick fuse or automatic breaker it will drop first time, but may hold the second. Your inverter may be has fast fuse 2 - 5 A. If not so fast it may carry the initial load.
Hint: If you are not "both left handed" you can connect  20 - 200 Ohm (2 - 10 W) resistor in series to your Laptop Power Supply. After the initial start of the inverter you can shorten the resistor by a 3 - 5 A switch.
Jul 01, 2010 | Vector 1000w Power Inverter
When I turn microwave on it blows 60 amp fuse
60 amps times12 volts = 720 watts times 80% effic of conv. = 576 watts available for microwave...
You must have a very tiny microwave as most require at least 1000 watts input power. That might have something to do with blowing the fuse. Since the microwave has a very reactive inout, you need a goodly safety margin above the rated watts input.
Jan 10, 2010 | Cobra Electronics - Others
Fuse blow as soon as it plug it in
sounds like your inverter has died :)
Jan 21, 2009 | Car Audio & Video
Jan 13, 2009 | Atd Tools 2000-Watt Power Inverter # 5955
Power inverter blows fuse in car
overloading fuse on cars wiring try direct connection to battery
Dec 27, 2008 | Audiovox Jensen Jp 20 Single Outlet 160...
Electronics - Others Logo
149 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
