Question about ASUS MeMO Pad 8 ME181C-A1-WH 8-Inch Tablet White
How to install turn off button on start screen, pls?
Hot to install turn off button on start screen?
    Top Expert:
  • ASUS Master
  • 10,875 Answers
Read your manual
Posted on Apr 26, 2015
My i pad is stuck in sleep mode
Perform a hard reset: Press both the Power and Home buttons and hold them down. Keep holding both buttons down until you see the Apple logo appear on the screen. The logo should appear between ten and twenty seconds after you start holding the buttons. After the Apple logo appears, your iPhone or iPad will boot back up normally.
Charge your iPhone: Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
Get iPhone into Recovery Mode: Turn off you iPhone and just plug the USB cable into computer > Hold the HOME button when you connect USB to iPhone > Release the HOME button when you see the iTunes logo.
The Most Common iOS 9 9 2 1 9 3 9 3 3 9 3 4 Problems and Solutions
Aug 17, 2016 | Apple iPad (16 GB) WiFi Tablet PC
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Message says unfotunately com.android server has stopped. I tried clearing the message by pressing OK, no luck. I have repeatedly turned tablet off then on tried accessing home, tools, browser no luck
sounds like you should read up on how to re install android on your tablet or maybe flash cyanogenmod 11 to it, ur current install is corrupt you could try removing all google apps and clearing their cache/data
Oct 19, 2014 | Samsung Galaxy TabPRO SM-T320 32 GB Tablet...
How do you fix a white screen?
Not sure what you've tried so far, but have you downloaded and installed the firmware update? You will have to download it to a Micro SD card using a computer. Once you have it downloaded, insert the card in you tablet then to a hard start up. Do this by holding the power button and the volume down button at the same time. You will be asked what you would like to do. Select install upgrade from SD card. Once that is done, restart tablet. Good luck!
Jun 24, 2014 | Polaroid 7-in. Internet Tablet - Other
Coby mid8065
1. Turnn completly off the tablet.
2. With the tablet turned off, holding the return button while turning on the tablet-pressing power button. Keep holding the return button until you see the Hard Factory reset screen.
3. Confirm the hard reset procedure. Once done, simply wait until process has finished-the tablet will restart. This process can take up to 30 minutes, so it's very important that the battery of the tablet is completly charged before attempting the hard reset. If you can connect it to the charger while resetting, even better.
Regards! If that helped, don't forget to accept my answer!
May 31, 2014 | Coby MID8065-8 - Kyros MID8065 8 8 GB...
Tablet keeps restarting
the software problem may be, try re install the os
May 31, 2014 | Sungale ID706WTA Tablet
My HKC A072D will not go past the initial HKC start up screen, at all, nothing has helped so far
This happened to my nieces HKC 7" Tablet and I held the Power button and the Home Button down for about 10 to 15 seconds and it reset everything and is still working to this day
May 08, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Jan 24, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
I want to change owners so I want to reset Kyros 8024. How do I do that?
Following the instructions below will cause losing all user data, including the third party installed applications.
This action will even delete the "Getting started" video file, which will cause the "Cannot find video" error when a user is trying to play the video clip using the "Getting started" application. With knowing this fact, the user can follow the instructions below.
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Jul 20, 2011 | Coby Kyros 716829701508 Tablet PC
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
Apr 11, 2017 | ASUS R1E-B1 Tablet PC
ASUS MeMO Pad 8 ME181C-A1-WH 8-Inch Tablet White Logo
70 people viewed this question
Top ASUS Tablets & eReaders Experts
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
