Question about Brother Sewing Machines
The tension on my Brother LX17 has gone wrong, and I cant correct it with the tension dial.
The thread from the bobbin is looping up on to the top of the fabric and some stitches underneath are looping. Do I need to adjust the bobbin tension? How?
    Top Expert:
  • Brother Master
  • 52,135 Answers
I am a new sewer have a Brither BM-2600 what numbers on the dial do I have for just plain stitching I have tried lots of combinations but the cotton underneath is all bunching up and not sewing right
I am not sure as to your machine, are you saying a "brother" machine? If your tension is set, say on 6 and it is too tight, turn the dial one more number......to a 7 or to a five and then check again. Also, I would rethread the machine and also take the bobbin out and then put it back into the machine. A lot of times, the bobbin isn't threaded into the machine correctly and it bunches up. Also, you can't use certain thick thread on some machines.
Jun 05, 2017 | Sewing Machines
What tensions should the the 4 dials be set at
here are my suggestions
change needle--make sure needle is correct one for fabric and thread
adjust top thread tension
rethread top thread using every thread guide
make sure bobbin is turned correctly in the bobbin case
Apr 07, 2014 | Sewing Machines
Tension is loose underside
Loops appear on the surface (top side) of the fabric?
Reduce the tension by turning the upper tension control dial to a lower number. If the loops still appear on the surface of the fabric after you adjust the upper tension, the bobbin thread may be too loose. In this case, turn the screw clockwise, being careful not to over-tighten the screw, approximately 30-45 degrees to increase bobbin tension. After you adjust the bobbin thread, adjust the upper thread to match the bobbin thread.
Make sure you reset before your next project.
Apr 26, 2013 | Brother LS-2125 Mechanical Sewing Machine
How do I adjust the tension on my Brother VX1020
First. pull the thread out and rethread the machine with the presser foot in the UP position. Set your tension dial to about 3 or 4. Do a test seam. Remember, if you have loops on the bottom, the top thread tension needs tightened. If you have loops on the top the top thread tension needs loosened.
Also on this machine make sure the bobbin is loaded in the carrier when holding the bobbin facing you should spool off the bobbin in such a way as to make the bobbin spin clock wise. If you load it backwards it will mess up tension, fray the thread and generally make you go bonkers trying to figure out what's wrong.
Here's a helpful page...
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Brother_Sewing_Machine_Threading/brother_VX_1010_1020_threading_diagram.htm
Oct 24, 2012 | Sewing Machines
I have a Singer 3140, and I have misplaced the book. I need to adjust the tension so that the threads are balanced, but have forgotten the correct procedure.
Get some scrap of the fabric you'll use.
Remember this phrase. Loops on bottom top tension too loose. Loops on top... top tension too tight. (or bobbin tension too loose)
In your case you need to loosen the top tension until you start to see loops on the bottom... then tighten it slightly.
Here's a manual for future reference
http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf
Jul 19, 2012 | Brother SE-270D Computerized Sewing...
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have gone over the threading of the machine several times and still I cannot get the bottom thread not to loop. Tried the setting dials. I can get the top stitch to look correct, but the bottom is a...
Actually, it sounds like your upper tension is too loose. If the upper tension is too loose, it won't pull the bobbin thread up into the fabric properly. Check out my suggestions on Adjusting Tension and see if that helps.
Robbie
Aug 01, 2010 | Brother XL-2600
The wrong loops are on the surface of the material that I've sewn
Loops on the top of the fabric are usually caused by the bobbin thread not in the bobbin case tension correctly, remove the bobbin and reinstall it. You should feel a slight resistance when you pull on the bobbin thread.
May 29, 2010 | Brother CS6000i Computerized Sewing...
Sewing Machines Logo
69 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
