Question about Applica Black And Decker 3-cup Rice Cooker Rc3303
It stopped working after less than 2 weeks, what can i do to fix it?
It dose not light up or warm up when tuened on
    Top Expert:
  • Applica Master
  • 48,549 Answers
Only 2 weeks from new return to place of purchase and get replaced
Posted on Apr 05, 2015
Space heater stopped working
First, check the warranty to see if it still in effect. I suspect a bad contact, broken control or problem with the heater element connections. If there is no physical damage from being dropped, tripped over, etc., then something like this would be a manufacturing defect (premature failure). If it's out of warranty, and you know how to use a multimeter, you could unplug the heater and start checking the continuity of the parts and wiring inside.
Jan 07, 2014 | Holmes Products Heating & Cooling
P0300: SOMETIMES rough idle, shake a lot OR less power above 50mph then got this code
Spark plugs in your car are good for 100,000 miles. try changing fuel filter and add a can of B&G 44K fuel additive. This stuff is the best on the market and only available at dealerships. It conditions fuel pump and injectors, also absorbs water in fuel (methanol). Try this first, your car is too new for any other problems. this should help drivability and fuel mileage. If Nissan does not have B&G, I know Toyota does. Also stay with 91 octane fuel. Check oil and coolant often. do not risk overheating in traffic, watch your gauges......
Feb 28, 2017 | Nissan Sentra Cars & Trucks
Fule gauge dose not work right
Does it stick at about half full? I would fill up, the gauge would show full then after 60-70 mile when gauge should show less than half to a 1/4 tank the gauge still showed 1/2 tank so I'd go ahead and fill it up. Finally, I watched my mileage and when my yellow low on gas light came on I filled it half full. After a couple of weeks I filled it up and the gauge has worked every since.
Apr 08, 2011 | 1985 Ford Bronco II
My sons xbox wont play it gave this web address and a code E 74 what dose this mean?
Contact Microsoft if you xbox is less than 3 years old. They will fix it free of charge. It takes 2 weeks.
Jun 01, 2010 | Microsoft Xbox 360 Console
Radiator fan not turning on , it works but dose not come on when engine warms up .how do i either check the radiator heat sencer or could it be something elss . it worked a week ago. and just stopped . my...
you may have to replace the fan itself because the relay it maybe in your fan check all of the wires to the fan to make sure it does not have a loose wire also check your temp sensor by the thermostat give these websites a try a www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man
Mar 13, 2010 | 1993 Ford Tempo
Hi - we have a Miele T284 tumble drier which is 2 weeks old and seems to have developed a fault. The machine stops after about 30 seconds with the buzzer going and Finish/anti crease light on. This is...
if this unit is only two weeks old,its safe to say its under warranty ,if you can't remedy this yourself by consulting the owners manual,contact the place of purchase &/or the manufacture,i'm sure they will be glad to repair or replace the dryer.any attempt by you or any unqualified person to repair this will void your warranty.hope this helps.thanx for using fix-ya
Nov 25, 2008 | Miele Washing Machines
We have an RS21 fridge freezer. Always freezing up. Last week, under the newly announced extended warranty (seen on Watchdog) it was 'fixed' again with some new parts. Fine for a week BUT Today it has...
Time to check the defrost timer, these can go bad on defrost and warm up the freezer / or on run mode, and cause the freezer coils to frost up..it usually will cycle 2 or 3 times a day. If you can find the timer (bottom, near floor) it can be rotated to cycle. (there are about 5 wires connected to it (it's about the size of pack of cigarettes.)
Apr 21, 2008 | Refrigerators
X box 360 system crashes
microsoft have extended theyre warrenty on xbox 360consoles to 3 years with the ring of death problem... so microsoft shuld fix it free of charge just bring it to wherever you bought it and they should take care of it.
Aug 27, 2007 | Microsoft Xbox 360 Console
Applica Black And Decker 3-cup Rice Cooker Rc3303 Logo
171 people viewed this question
Top Applica Kitchen Appliances - Others Experts
ray gallant
Irene Tulloch
Tom Chichester
Are you an Applica Kitchen Appliances - Other Expert? Answer questions, earn points and help others
