How do I configure the lnsydeH20 once im there
Im trying hook up a wireless router and it ask what kind of conection I have static ip ect... How do I know what I have? Im using DSL.
Most residential subscriber services use dynamic IP addressing. Dynamic IP addressing is automatic from your Internet Service Provider (ISP). Linksys home based products such as the one you have should be setup up for this configuration out of the box by default, and require no adjustments to the IP configuration of the wireless router.
You should power down the DSL modem and Linksys, then connect them, then reapply power. This will clear the DSL modem if it was connected to another device such as a PC. This is important as most cable and DSL modems use something called MAC address binding that will only allow one device to connect to it directly at a time.
Feb 06, 2010 | Linksys Wireless-N WRT150N Router
Problem with cect a88
first of all install the GPRS settings sir
Jun 11, 2008 | Cell Phones
Help I have a webcam built-in to my fujitsu laptop, how does it turn on??
Webcams are either started by their specific programs or they are used by the IMs that you use. To use with the IM you must configure the IM (Skype, Yahoo Messenger, MSN or whatever you have) from their respective Tools->Options->Video to use this webcam as the default camera. Also in the Audio option you must use the built in mic of this laptop as the default mic.
Once you have done this then everytime you use the IM for video talk or just talk then the webcam and mic or just the mic will be used automatically.
While if you use the specific program to use the webcam then the webcam and mic will be used without any configuration. However, you must configure things like mirroring and colors etc so that when you move to the left the video should show you moving left and not otherwise.
Happy Holidays.
Dec 25, 2009 | Fujitsu LifeBook A6110 PC Notebook
HI! I got my Pc set up through a Dlink 1005d to a router. Im able to access internet fine.. Now my problem is that I also want to connect a media player to the DLink aswell.. What happens is when I try...
It probably isn't an overload the flashing lights are probably the new device doing a broadcast trying to find something that will tell it how to configure its network port. This process is called DHCP (Dynamic Host Configuration Protocol)
Normally your router would be automatically configured to be a DHCP server. If you have not needed to manually configure TCP/IP on your desktop computer then You have a DHCP server turned on somewhere.
Your next step should be to find out where your DHCP server is and if your new device has contacted it. Find the manual for your router and have a read about how to configure it expecialy the bits about DHCP.
Then open a command prompt. Sometimes called a dos prompt by typing cmd in the start run box and type ipconfig /all The Default gateway should tell you the IP number of your router. type that IP number into a web browser like this. http://192.168.0.1 (or what ever it is) you should see a configuration logon page for your router. The username and password will be in your users manual or just google it. From here go into the DHCP server screens and you should be able to see what IP numbers have been assigned on your network. Hopefully one of them will be your new device. Also you need to make sure that you only ever have one DHCP server on your network. PC's can also perform this function. If you have more than one running it will very dificlut to diagnose. If you see ip conflict errors this is probably the cause.
Netowrking is complex and there is lots you need to know all at once. Luckily home networks are relatively simple once you know what all the pieces are. This should give you a taste of what you need to learn about.
Good luck :)
Aug 15, 2009 | Computers & Internet
Flashed from verizon to metro pcs cannot get pictures or applications or on web how do I configure phone to connect to metros web settings?
Metroflashing is for VOICE service only, and Verizon's software is not designed for use on Metro's network. In other words, if you don't know how to get into the phone's programming, you cannot set up this phone's user name and password to get on to Metro's data services using the handset. You can, however, use the phone as a dial-up modem for your PC.
Once Metro can come up with a way to access the user name and password of the phone's software, they will then let you get data services (e.g. picture messaging, internet, etc...) on your phone.
May 03, 2009 | LG VX9800 Cellular Phone
Scsi raid with battery backed memory for pweredge 2550 server
if my memory serves me correct i think this server uses a onboard (3di) card it is set in the bios to use the raid configuration, under integrated devices .make sure this is so ,as it boots press f2 key to enter.If this is so exit.next step is to shut the machine off pull the drives away from the backplain not completly out. Power up if it starts laoding the raid configuration,once the scan is complete it will give you a container not found error,now here is what you can do go in i think its control m or r,anyway look at the configuration and what raid you set it up for.write down the drive number 0-etc.ok the next move is the raid key a little device that sits on the motherboard beside the raid dimm reseat this,now you may want to replace the raid dimm or if you have a exact match for troubleshooting purposes you may try this.
Good Luck
Feb 05, 2009 | Dell PowerEdge 2550 Server
Please help
hello!
are you trying to access the router setup?
are you trying to configure the router?
i have read the same problem on the supportrix forum and you may try this simple steps and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
Aug 14, 2008 | D-Link DI 514 Wireless Router (DI-514)
I have a us robotics wireless model 9108 router. I have just bought a dell inspiron laptop with vista home premium and am unable to connect to the internet. can you help?
ushally you will have to set up your connection being connected to the router via the lan cable once you do that you can configure your laptop to be allowed to run on the wireless setting.
so if you have another computer hooked upto it you can set the permissions on that you have to create a new network for the laptop.
if you have the manual you can find the configuration settings for your router, most you just open up Internet explorer and then type in home to access this menu.
but for your unit im not 100% sure of the configure setup for it.
Aug 11, 2008 | Computers & Internet
How do i sync windows vista with my router?
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
David Payne
David Payne
