Question about Samsung Sch R220 Jitterbug Plus Android Phone Cdma Tft Silver
How to reset to factory default ?
Reset to factory
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
Factory reset
Use Default Settings If you want to return the initial language setting such as Language, Video, Audio and etc. to the factory default, do the following: 1) Press SETUP button. 2) Press / button to select Misc. 3) Press button to select Use Default Settings, then press ENTER button. 4) Press / button to select "Yes", then press ENTER button. The original setting will be restored. Screen saver : On Do you want to use default setting? Note When you reset the DVD player to the factory default, the DVD player will take 3-5 seconds to reset.
Oct 15, 2014 | Toshiba SDK990 Player
I need a code for a kodakhero printerphotocopier 7.1
I don't believe that model has a password. You may just need the password for the network you are using. If you want to reset the unit to the factory defaults see below.
To reset defaults to the factory default settings:
1. Press .
2. Touch , then touch Printer Settings.
3. Touch , then touch Reset All Settings.
4. When you see the message, "This will reset printer settings to factory defaults,"
touch Yes.
NOTE: Resetting factory defaults does not change the date and time, language, or
country/region.
Jun 19, 2014 | Netflix
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
I am looking for the Security Key
Unfortunatly there is no way of accessing the router security key if you have forgotten it however you can reset your router to factory default here is how
" The Reset button is located on the right side of the product label. There are two ways to reset the Router to its factory defaults. Either press and hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen in the Router's browser-based utility The Reset button is located on the rightside of the product label. There are two ways toreset the Router to its factory defaults. Either pressand hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen inthe Router's browser-based utility" was this helpful?
Oct 05, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Samsung Sch R220 Jitterbug Plus Android Phone Cdma Tft Silver Logo
241 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
