Question about Onan Cummins 4.0 KY-FA/26100 RV QG 4000 4000K Gasoline Generator Micro
My generator runs great but when i turn on a/c it runs about 40 seconds and have a code 15 then reset turn generator back on let it run and turn on microwave and does same thing what do i look for?
Model number 4KY FA26100J
Have a Tahoe 7000 diesel ,runs great except when you turn on breaker with no load. runs about 7 to 10 seconds and shuts down, Can you help
Hello dear, have you found any effective ways to solve your problem? If you haven't, visit this website to know more information about generator tech.
Generator Set Diesel Generator Cummins Volvo Perkins Generator
Sep 06, 2017 | Chevrolet Tahoe Cars & Trucks
Car stalls after 10 to 15 minutes of driving
ease the frustrations by having the fault codes read to find the faulty sensor
fix that first
May 12, 2016 | Cars & Trucks
Why does the Change Oil light stay on for 15 extra seconds?
TAKE THE TRUCK BACK TO PEPBOY AND TELL THEM TO RESET THE SERVICE INDICATOR
Sep 02, 2014 | 2003 Chevrolet TrailBlazer
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Have Onan 3.6 KY propane gen that will not keep running. Runs only as long as start switch is pushed. Then stops immediately after release. Fault code is 15 (underfrequency) and suggests removing heavy...
I am not familiar with your peice of equipment but from your description of the fault being Under Frequency it appears that generator governor is out of adjustment or the governor spring has brcome weak or broken and not allowing the engine to run at the correct speed to produce an output frequency within the allowable tolerance. Governor linkage could also be binding and not moving smoothly to respond properly to engine load conditions. Thoroughly check governor and throttle linkage for free and smooth operation and full range of movement.
Another cause could be that the engine is not getting sufficient fuel causing the governor to have the throttle wide open to try to get engine to run at its correctly governed speed but unable to do so because the engine is not developing enough horse power.
Jan 10, 2011 | Watts Onan Portable Generator - 4000 ,...
Generator will start and run easy, then just die.
Check for loose wiring connections, especially at the run or kill switch. Generators vibrate a lot so it could be as simple as something loose.
Jun 15, 2009 | Electrical Supplies
I have a Generac MC 5500 portable generator. It
when power tools get old they draw more amperage. 6.8 amps new might be 8 amps. over loading when older.
Apr 16, 2009 | Hammering
Onan Cummins 4.0 KY-FA/26100 RV QG 4000 4000K Gasoline Generator Micro Logo
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
