Question about Vizio VW32L 32 in. LCD HDTV
Should i have a built in digital tuner
Cant get digital tv.do i have to have an antanna or not?
  • 21 Answers
Your TV does have an inbuilt Tuner. You will need a Digital compatible Antenna. There is a big difference between digital and the old analog TV Antenna's
Hope this helps :)
Cheers Peter Smith
Posted on Apr 05, 2015
Do you know if the Visione VISLCD2408 TV has a BUILT-IN DIGITAL TV TUNER or does it only have a ANOLOG TV TUNER ?
If you can tune digital channels directly, e.g., 10.1, 29.2, the tuner is built in.
Jul 08, 2016 | Televison & Video
Why cant I change channels when recrding 2 progs?
Hello Anonymous,
You did not specify if you are using a DVR capable cable/satellite box, which I what I presume is the case.That DVR has two tuners in it - each tuner allowing you to watch and/or record two programs at one time and in any combination.If both of those tuners are used for recording then you cannot watch another "live" stream as there no available tuners to tune and display (or stream to the DVR hard drive for recording). You can only switch between the two recording programs.
As a side note, if your TV has a built-in tuner, you can split the cable and have one going to the DVR and the second run going to the TV set. You can then use the TV's built in tuner and watch what anything it can get. It won't get scrambled digital cable but will get analog and Clear QAM channels.
Feb 15, 2015 | Televison & Video
How to switch from analog to digital
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Feb 24, 2014 | Computers & Internet
Does my Insigna Tv Model number NSFTV27, serial number 065260705675 have a built in digital tuner? Also, what kind of antenna should I get for this model?
Hello
Your Insigina TV has no built in digital tuner. It has VHF/UHF/CABLE IN tuner. It is not a digital one. OK.
Jun 13, 2011 | Insignia NS- 27" TV27 TV
I have a nspdp42 plasma and i cant affort cable and want free tv. is there a analog to digital converter in the unit already? the model # is 801rmd2237770 Thank you
The Insignia NS-PDP42 Plasma HDTV has a built in ATSC/NTSC/QAM tuner.
In short, yes, it does have a digital converter built in, but you will need a antenna capable of receiving digital broadcasts. You can find these at Walmart for $15 to $60.
Mar 05, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How can i tune my tv in to recieve freeview channels?? tried everything with no luck. cant even get analogue channels? i know this isnt a problem with the aerial as other tvs work!!
In the US, you are not able to obtain free HD channels without a tuner and an antenna. Some HDTV's have built in tuners and depending on your location to the broadcasts, you may be able to obtain reception. It is possible that one of your TVs has a built in tuner if it is newer and this other TV does not. Analougue channels no longer exist as all channels have been converted to digital broadcast and would need to be converted if trying to view through an analogue TV. Thanks.
Feb 28, 2011 | Televison & Video
Try to re tune but it goes throught the motions but does not pick up any channels at all. Tried this many many times. all cabled up correctly. help required please. Its a TWFdigital STB501 Box (Digital...
You need to have a newer digital antena hooked up to it also if your tv is flat panel and its less than say 2 years old the digital tuner should be built in. I dont mean to sound dumb but if you are using a digital coverter box and thats what the antenna is hooked up to make sure your in the menu of the converter box. You can determine this by what channel the TV is on. If you hooked the Box to the coaxle then your TV should be on 3 or 4 if you used Composite(RCA) cables then it should be on aux. But once again I will say the antanna makes all the difference with digital. Old ones do not work. Please respond with more info if this doesnt help.
Dec 14, 2010 | Televison & Video
Does this tv have a digital tuner or will I need a converter box?
Coby tf-dvd1540 tv
No ATSC tuner in this TV. You will need a converter.
Product Features
  • 15-inch flat-panel TFT LCD TV with built-in side-loading DVD player
  • Standard 4:3 aspect ratio, native 1,024 x 768 resolution
  • Plays DVD, CD and recordable MP3 music CD-R/CD-RW
  • Built-in NTSC TV tuner lets you switch between DVD and terrestrial broadcast viewing
  • Stereo speakers with 3 watts per channel; includes full-function remote control; onscreen display simplifies setup and operation
Technical Details
  • Brand Name: Coby
  • Model: TFDVD-1540
  • Display Technology: TFT active matrix
  • Display Size: 15 inches
  • Image Aspect Ratio: 4:3
  • is_hdtv_compatible: N
  • speakers_included_description: 2 speakers
May 13, 2009 | Coby TF-DVD1540 15 in. TV/DVD Combo
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Pip on d52w20
when i was on digital cable my pip didnt work either. with sat, the box offers a pip feature. if you have basic cable or using an antanna the pip on your tv should work. maybe its just your cable or sat not allowing you to use that feature.
Aug 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vizio VW32L 32 in. LCD HDTV Logo
54 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
