Question about Miscellaneous
There are strange noises coming from the dashboard maybe the airvents of my car. What should I do? It is annoying.
2004 GMC Envoy XUV w 167,000 miles. The problem was first noticed 8 months ago after getting the car back from my daughter who is a forester. It sounds like the car is possessed. It's squeaks it screams. Mostly heard coming from the right dash. Short burst
    New Friend:
    Problem Solver:
  • 9 Answers
HEATER FAN OR AC FAN BEHIND THE GLOVE COMPARTMENT
Posted on Jun 08, 2015
  • 3,462 Answers
Do you think, (hope this does not sound too odd,) that something might be under your dashboard. Found the odd mouse in a car now and again!! Seriously, it only when the vehicle is in motion, correct?
If the sound is very annoyin you could always get a local garage to check it out.
Posted on May 29, 2015
  • 599 Answers
SOURCE: liquid noises coming from the dash board
heated water goes to your heater core under your dash..though you shouldnt be hearing it usually..be sure water level is up at radiator overflow reservoir and pay attention in cabin of any sweet smell of coolant indicating a failing /leaking heater core....look for damp carpet on passenger front area if suspicious
Posted on Oct 07, 2008
  • 51 Answers
SOURCE: suspension groans when making a left turn
sometimes the noise is in the steering wheel the plastic is rubbing together causing that sound.
Posted on Oct 08, 2008
468 Chevelle
  • 81 Answers
SOURCE: 2004 GMC ENVOY XUV, spare tire system stopped working
The tools are under the second row seats. The hole for the spare tire lowering mech. is above the rear bumper when you lift the tail gate. Put the proper tool down the hole, turn counter clockwise, lowers spare. Reverse to bring up.
Posted on Apr 05, 2009
SOURCE: fuse
The second fuse panel is under the rear seat.
Posted on Jan 07, 2010
  • 3600 Answers
SOURCE: 2004 GMC Envoy XUV mid-gate window won't roll up
be sure the gate is fully closed or it will not roll up if it is firmly in place and still does not go up you will have to remove the cover and see if the actuator plastic has broken off from the switch, it also could be a bent rod and or the switch is bad. Check fuses as well just to be sure before going to all the other work to pull cover off. Hope this is helpful and thanks for using Fix-ya.
Posted on Jan 19, 2010
How do i bypass roof module and manually close roof on 2004 gmc envoy xuv
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 15, 2018 | GMC Cars & Trucks
Only 1 speaker works on my stereo on my 2004 gmc envoy xuv the front drivers side
Usually the radio or amp died. Speakers do die, but usually have a scratching noise, mostly at bass parts.
Dec 21, 2016 | 2004 GMC Envoy
How to fix my rear tailgate window
check the fuse/relay. if it is neither of these check the switch with a multimeter. If you can hear the motor trying to move the glass when you try the switch it may be the regulator needs attention. It may be the motor needs to be replaced.
check fuse and relay along with the switch first then the regulator and motor afterwards. Replacing the small electronics is obviously easier than having to open up the tailgate to check the mechanics of the winedow.
Sep 13, 2015 | 2004 GMC Envoy XUV
My 2004 GMC Envoy XUV rear sliding roof is stuck in the open position. How can I manually close it?
Check owners manual! there should be a manual override for situations like this usually there is a hand crank that usually comes with the car.
Mar 27, 2011 | 2004 GMC Envoy
2004 Envoy xuv 6 cyl stalls with A/C on at idle
2004 Envoy xuv 6 cyl when I turn on the A/C the truck stalls but as long as I keep my foot on the gas it will continue to run
Jun 11, 2010 | 2004 GMC Envoy
I have a 2004 xuv envoy with 115k miles. The
i would say it's long overdue. i would think the manufacturer would recomend changing the trans fluid at 25,000-30,000 miles. the owners manual will have regularly scheduled maintenance routines listed.
Apr 05, 2010 | 2004 GMC Envoy
FAN WOBBLES AND MAKES NOISE?
Water pump is going out and that is the first thing that happens
Jan 20, 2009 | 2004 GMC Envoy
Miscellaneous Logo
37 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
