I have a question. I have a cabrio washer and 99.9% of the time i wash clothes it will get unleveled and it stops the wash cycle. What could be wrong?
I need to know why it gets unleveled everytime i wash clothes?
    Problem Solver:
  • 13 Answers
You are loading to much into it.
Posted on Apr 05, 2015
Testimonial: "Thats not the problem. It doesnt matter what size load i have in there. it will wash but when it starts to spin the UL code comes up. Why is that."
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
Kenmore 70 series washer was in spin cycle when the clothes within caused it to become unleveled and it was rocking. I lifted the lid to adjust the clothes to level it and found that lifting the lid
sounds like you need to adjust the feet under machins a little .Lifting lid while runnning is supposed to stop the machine .ans adjusting the wet clothes is mfg suggested fix of unbalance .
Jan 06, 2015 | Kenmore Washing Machines
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
How to restart the cabrio washer
my washer when spins knocks like crazy from the inside when spinning and sometimes when on the wash cycle washer keeps saying unlevel but clothes are level
Aug 14, 2012 | Washing Machines
My cabrio waher will not spin on the last 12 min of the cycle...it displays ul everytime...it is not unlevel we have checked
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
Jan 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The last 8 or 9 minutesof wash and spin cycle, washer said that it is unlevel and stops, but I check and clothes are level
If your tub is level, then check the feet of the machine. If they are not leve, you will get the same error. Use a level if needed to check.
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Unbalanced load cabrio top loader
being un-level could certainly cause it im currently working on this problem for another customer on this site while i haven't had hands on with this model yet i just finished reading the service manuel on it its kind of an amazing concept in washers if either one of you are on line reply to this message hold my rating for now as i need to ask some questions
Dec 23, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
