Question about Maytag Washing Machines
Soap dispenser release detergent as soon as I pour it in. Drips down int drum while pouring - before shutting dispenser. Any ideas?
Maxima XL steam
    Problem Solver:
  • 13 Answers
Check and make sure something isn't stuck that it making it stay open. maybe you need a new spring (or whatever it uses) to keep it shut.
Posted on Apr 05, 2015
Testimonial: "Once you pour the detergent into the reservoir it immediately pours out, down ito the drum. Nothing to do with opening or closing the reservoir."
Why maytag neptune washer water pouring out soap dispenser door?
Either there is a sock stuck between the inner tub and the water
inlet to the tub or more likely you have been using to much liquid detergent and cold water wash all the time . This can cause the supply tube below the dispenser to be plugged up. Have fun cleaning it. Warm wash should always be used. Detergent needs the heated water to work properly .
only other possibility is mice building a nest if the washer hasn't
been used in along time.
May 09, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
Water is leaking out from the place where you pour the liquid detergent into.
Sounds like you have a blockage here, try pouring kettle of water in and make sure goes away/remove clean soap dispenser if not and check for any obstruction in soap to drum hose.....
Jan 31, 2011 | LG WM2487H Front Load Washer
Whirlpool Duet Sport Leaks from under detergent dispenser
there is a hose that runs from the soap box to the drum to let the water into the drum if it is not connected or has perrished then that would explain the waterfall
Jun 11, 2009 | Washing Machines
Water pours from detergent basin-Whirlpool Duet Sport
first remove dispenser pull out and make sure its not clogged inside,w/ hand fill around ,, on any frontload machine i perfer liquid soap,, are you using HE detergent
Jan 03, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Leaking Washing Machine
no you should not need to spend any money on this . it sounds like the hose going from the back of the soap draw to the drum may be blocked just boil your kettle and pour it into the draw if this clears the blockage you wil see steam in the drum then put more hot water about another 2 kettles full down the draw and push the draw in and operate machine on the spin cycle. if the blockage is still there take off the lid you will see the hose from the back of the soap box and sqeeze it this should release the blockage
Nov 11, 2008 | GE WBVH6240F Front Load Washer
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Cleaning Solution
just in the soap dispenser as soon as it starts filling.
May 01, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Dishwasher Tabs
THIS IS JUST A SUGGESTION: TAKE SOME WARM TO HOT WATER AND POUR IT DOWN AND AROUD THE DISPENSER.
SOAP CAN "CAKE-UP" AND MAKE THE THE DISPENSER STICK. IN THE MEAN TIME YOU CAN PUT YOUR DETERGANT IN A COFFECUP ON THE LOWER RACK AND ACHIEVE THE SAME RESULTS. ALWAYS USE THE LEAST AMOUNT OF SOAP POSSIBLE.
GOOD LUCK
Feb 08, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
I put laundry soap in the dryer by accident
DO NOT pour water down the lint filter of a dryer! This could have catastrophic results. There are live voltages present in a dryer even with the power shut off. You have a blower fan and a motor in the air baffle. Pouring water in there will definitely damage something (if the soap hasn't already). Detergent is a corrosive and will damage anything electrical and any painted surface if left too long. I hate to say it, but you must open the dryer up and remove the air baffle and clean it out thoroughly. Unplug the machine before you attempt. You need to wipe up all the soap residue with rags. You will need to let me know if the dryer has a lint filter on the top of the machine, or in the door before I can suggest how to disassemble. This will make a big difference in the amount of effort required to correct this. Post me back with the info...
Aug 08, 2007 | Kenmore 60172 Electric Commercial Dryer
Washing Machines Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
