Question about Cameras
How to fix electric akiles cardmac slitter
How to fix
Megabind 1 binding machine comb opener is stuck
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 10, 2012 | Akiles MegaBind 1 Plastic Comb Binding...
I installed a tv in my bedroom but I can't get the same channels as my tv in the livingroom. I only have an antenna. What could be the problem. It says that some channels are not available.
you do not state what type of antenna you are useing ,i would suggest you run seperate coax run from the antenna to your tv in the bedroom you can use a slitter box at the antenna and run it to your tv if this doesnt work ,try a booster at the antenna
Nov 14, 2010 | LG 37LG30 37 in. LCD HDTV
I have a brand new Logitech 9000 but when I zoom it gets blurry. I cant take a close pic of my eyes. I have to put the camara close to my face to do it. Why cant I zoom into my eyes like many web cams and...
It could be the cam doesn't have enough power. Might you be running a machine thats a few years old? Try getting a usb slitter / hub that has it's own power source. Thanks
Feb 21, 2010 | Logitech QuickCam Pro 9000 Web Cam
I need to remove the front shock absorber on my 2001 Jeep Grand Cherokee Limited, 4.7L engine. When I try to loosen the top shock nut, the entire spindle turns. I cannot find a way to lock the shock...
If you have a impact you can try spinning it until it snaps.I'm not sure how much clearance you have .Is there enough above the nut for a vise-grip.More than likely you will have to smack it with a hammer (bend it back and forth),not sure if there is room to put a nut slitter on it.Or hack saw it off if you are limmited on tools.
Dec 27, 2009 | 2001 Jeep Grand Cherokee
Scanner will not initialize properly, can make
If the scanner is not positioned correctly ,indiferent to make a copy to use the ADF or make to the original glass the copy problems is identical.Clean the scanner glass,original glass and the white level band,the erase lamp and check the OPC drum.If the problem persist need to perform the FD and CD adjust for the paper tray.Make someone copies use the A4R tray,and A3,and see the different.
Please answer to help you.You need the position correctly the problem source.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Re: Quad 11L tweeter doesn't work
If you sure it is working and new then ,maybe connection error,try to review the hooked up connection maybe there might be interchange;
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 25, 2008 | Quad 11L Main / Stereo Speaker
Re: Quad 11L tweeter replacement
Given the relatively small cost of the repair, I'd have the servicer do it. That way if anything happens, he/she is respionsible for it. When I repair this type of speaker, I usually use an old chisel. It is sharp enough to get under the edge and strong enough to pry up the speaker. Just be careful not to nick the cabinet.
Dan
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Printer keeps taking paper crooked
on the ADF?
which glass is broken? the platen glass or the slitter glass.
If the paper is going in crooked it means that the papaer is getting stuck where the obstruction is
Apr 21, 2008 | HP PSC 1510 All-In-One InkJet Printer
Piping TV throughout house
Yes, this is done many times. If you do have a degraded picture because of all the slitters you can just add a antenna booster amp to compensate.
Jan 07, 2008 | Televison & Video
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
