Question about Breville Die Cast 800ESXL Espresso Machine
How do I fix my Breville Espresso Manchine 800ESXL. there is no pumping action to force the water through the head
2 Suggested Answers
SOURCE: brand new breville 800esxl espresso
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Posted on Sep 17, 2011
Replace pump breville 800esxl
How to replace the thermostat in the breville 800esxl machine
Nov 07, 2013 | Breville Die Cast 800ESXL Espresso Machine
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
  • Rank: Apprentice
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Die Cast 800ESXL Espresso Machine: Breville 800 EXL espresso machine pump not working...
I have the same problem. I used my machine for one day to test it when I had it brought into Vietnam then packed it while our house was being built.
Now it won't pump water or produce steam.
To add insult to injury Breville advice "They don't give service manuals to the public"
May 17, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine no suction but pump operates (makes noise). Cant find any obstructions in internal plumbing? Could the thermal plate be obstructed? I will try blasting it with...
I had the same problem. I opened up the back and disconnected the water hose from the spring loaded intake hose and put the hose directly into the tube and into the reservoir tank. Now it seems to **** the water in again. Not sure this is the best solution but it seems to work for now.
If someone has a better solution, I'd be happy to hear about it.
Dec 20, 2009 | Breville Die Cast 800ESXL Espresso Machine
Water tank vibrates loose
Try some of the expanding foam insulation in a can. Don't use too much as it expands considerably.
Sep 18, 2009 | Breville Die Cast 800ESXL Espresso Machine
Breville 800esxl,won't stop pumping even in standby.
1- Are you using distilled water? If yes then the machine cannot sense the water level in the boiler.
2- Where is the water that is being pumped going? If it is coming out the drain tray, then the solenoid for the group needs to be replaced.
If it is coming off the top of the boiler, Then the level probe is calling for water, in which case you will have to remove probe and clean with a wire brush.
May 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Breville 800esxl won't extract coffee or steam milk.
is your machine new or is this a new problem? If you have had the machine for a while there is a possibility that your double wall filter is clog between the walls which would prevent the water from going through (this happens when your grind is too fine). If however the water does not go through when you do not have a filter in the basket than you have a diferent problem.
Jan 18, 2009 | Breville Die Cast 800ESXL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
FixmeBob Great help with Breville 800esxl
I had a similar problem, but no blinking light, only cold coffee. I tapped on the relay (black box on circuit board) and violá.  Red light, hot coffee, and happiness.  The machine did the same thing a couple of weeks after the "fix", and a good slap to the left side, and I was back in business.  My guess is that your switch is bad or sticking.  Good luck.
Feb 06, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
239 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Steve
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
