Question about Nikon Cameras
My nikon d300 will not format the SD card....
  • 28 Answers
Hi, Dear
Nikon D300 does not use SD card! It use CF card.
But if you have format problem in camera then I recommend format from a computer using memory card reader. And then put the memory card into camera and try to format! Here it does not, then you should show to your local repair shop and it will cost between $120 to $265 usually. In minor problem case it will be replacement of memory card acceptance unit replacement. But the problem come from main pcb then the estimate will be totally different!
Hope You Luck! A Professional Camera Clinic Guy
Posted on Apr 06, 2015
likha
  • 790 Answers
SOURCE: DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Posted on Nov 02, 2007
Steve5
  • 423 Answers
SOURCE: Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Posted on Feb 18, 2008
tjzteddy
  • 53 Answers
SOURCE: self timer on nikon d300
on the top of the camera, there is a dial which says QUAL, WB and ISO. Look for button and ring just below this. It should say S, CL, CH, Lv, a clock and Mup. Press the button to release the ring and rotate it to the clock icon to activate self timer
Posted on Jul 19, 2008
mackcamera
  • 33 Answers
SOURCE: Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
Posted on Dec 31, 2008
  • 102366 Answers
SOURCE: Nikon Coolpix L11 Memory Card Error
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
Nikon coolpix s630 shows memory contains no images no sd card in it
That is what you get when the camera memory has no images. And the SD card is missing. This does not seem to be a problem. The tool menu will let you format a new SD card.
May 05, 2017 | Nikon Cameras
My nikon d300 images are all soft, loads of grain
D300 use ISO till up to1000 after that it will form grain or if you want to use 2000 ISO then keep RAW format.
if its coming soft then please check lens got fungus
Jan 01, 2013 | Nikon D300 Body Only Digital Camera
My nikon d300 will not recognize any card. when I put the card in it shows chan in the window that shows how many pictures you have. It has never happened before and i checked my cards on my other camera...
I am a Spanish amateur photographer and I repaired my Nikon D300 with the same fault. In my blog there is a tutorial. In Spanish, but you can translate it with Google.
Mi Blogg.
Good luck
Mar 20, 2011 | Nikon D300 Body Only Digital Camera
Price for nikon d300
D300 can be found scarcely new. It has been replaced with a newer model D300S. The D300S incorporates video and both SD and CF capability for extended uses of writing the photos. One card can be used as backup, or one can be used to write RAW files and the other JPEGs. Some slight changes were added to the menu {active D-lighting}, and the D300S also was give a slight boost to 7FPS. Used D300 on the market go for $900 - $1300 depending on its history.
Apr 02, 2010 | Nikon D3000 Digital Camera
Today I removed my Sandisk memory card from my Nikon D300 before going on a photo job to replace it with an empty one but couldn't get the new one to go in-or the one I had just removed. The camera shows...
CHA error message means that the memory card is unusable. You should format the card by inserting it in a card reader or try another card.
Let me know if you need more help,
Sai.
Jan 18, 2010 | Nikon D300 Digital Camera
My d300 has suddeny decided a my memory cards are corrupt. They work fine in a card reader
When you remove the card reader from the computer, you must use the "safely remove hardware" function or your card will be corrupted. Sometimes, if you format the card in the camera, everything returns to normal (download the pictures first).
Dec 15, 2009 | Nikon D300 Body Only Digital Camera
Delete all image,nikon d 300
I assume you mean all images on your D300. Simply format the card.
Nov 06, 2009 | 2006 Audi Q7
D300 says "no images in folder" but I can download the images easily using a card reader. but cant view them on d300. Have checked the folder section on d300,but still no joy,they have vanished....
John it seems that the photo's have been placed in a locked folder or the format has be alter. to a no readable format by your camera I would contact Nikon about the issue they are pretty good with help desk, hopes this helps. The Q
Oct 30, 2009 | Nikon D300 Body Only Digital Camera
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
53 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
