Question about Echo Garden
Echo CS-400 chainsaw. I'm not understanding this diagram. I posted a picture of my carburetor earlier. Please tell me which fuel line goes to the 90° degree port on the carb? Thanks!
  • Echo Master
  • 1,169 Answers
The vacuum side of the primer bulb goes to it.......
Echo CS-400 chainsaw. I'm not understanding this d - 25629896-ngs4fwq21n25g5w0ie5abidp-1-0.png
Posted on Apr 05, 2015
3 Suggested Answers
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
  • 1169 Answers
SOURCE: I have a Echo chainsaw CS-400 and the carburetor has three nipples which two is on top of the carb and the other is at the bottom in a curve. which is the inlet for the fuel line with the filter
Walbro WT-820
Posted on Apr 04, 2015
Testimonial: "So the suction side of the primer is what you're saying? And the fuel line with the filter goes to the fuel inlet?"
What is the little black hose fuel vent for on my echo CS 400 chainsaw?
To let air into the fuel tank as the fuel goes down, otherwise there would be a vacuum and no fuel supply!
Jul 25, 2016 | Echo Garden
Echo CS-400 chainsaw is it better to clean or replace the gaskets in the carburetor. .saw won't start?
replace,ethanol in the fuel eats rubber,try to use gas without ethanol
Apr 07, 2015 | Echo Garden
Echo Cs-400 chainsaw. Standing the carb up with the sliver vent on top which fuel line goes to the 90° inlet on the bottom and which line from the primer bulb to the carb?
The lengths of the line and,or the bends in the line . I would say the line from the bulb would go the carb since it is used to prime or,choke the carb.
Apr 05, 2015 | Echo Garden
How do you hook up the fuel filter line inside the tank on a cs400
If you go online and search for the drawings for that saw you will see that the fuel pipe enters the tank at the top through a grommet. You will have to pop out this and then pass the pipe through this after passing it up through the hole from inside, long nosed pliers or tweezers will assist. Once you have that done stuff the grommet back into the hole and don't pUll it out again!!!!!!!!
Apr 03, 2015 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
Cs-302 fuel line replacement
How do I remove the Flywheel on a 1982 Echo chainsaw 302? I can't get to the fuel line since a piece got stuck under the flywheel.
Feb 01, 2014 | Echo Cs-302 Flywheel Assembly Cs 302
Idle to high
Make sure the carburetor was re-installed correctly as any air leak between the carburetor and cylinder will cause high engine speeds but almost no power. It can also scuff the piston/ring(s) and cylinder due to very lean lubrication from the fuel. Hope this helps!
Jul 12, 2010 | Echo CS400 18" Chain Saw
Open Questions:
Garden Logo
928 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
