Question about Husqvarna RZ4219 42 inch 19.5 HP Briggs & Stratton Zero Turn Mower
Bought brand new. Started and ran for about 20 seconds and then shut down while putting it in gear. Engine turns now but will not sart
  • Kprime
    Kprime Apr 12, 2015
    Hi Paul G, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Sooo, did you take it back to the dealer??
  • Paul G
    Paul G Apr 12, 2015
    The engine flooded. There was gas around the spark plug. Dried it off let it sit overnight and it started next morning. I was away until last night. Started it again and everytnihng was ok but did not put in gear. Took it out today, it started right up and then shut down when I pu it in gear. there was gas around the plug again
  • Husqvarna Master
  • 2,027 Answers
Call the place you bought it from and tell them that way you should be covered by the warranty. If you do it yourself they could not cover you. It could be a simple thing but you don't know that.
Posted on Apr 12, 2015
Brand new, ran for two minutes then died.
Did you put oil in the engine before it was started. If you purchased it brand new take it back from where you bought it. Could be such a thing as a dirty fuel bowl or fuel jet.
Jul 05, 2015 | Garden
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
Gas in crankcase
Fuel from the fuel tank flows to the carburetor and then on into the engine cylinders. From there it seeps into the crank case.
It's a matter of gravity. The gas will seep until it reaches the lowest point in the engine.
There are two methods of correcting this dangerous problem.
1) When you are done using the engine you can turn it upside down, over a large container that is of sufficient size to contain all the gas and oil that will run out of the engine.
or
2) Turn the fuel valve to it's OFF position when you are done running the engine. This stops the fuel from seeping into the crank case from the carburetor.
(And a heads up from one who has personal, first hand experience. Be sure to OPEN the fuel shut off valve when you think you would like to start the engine.)
If you should have this happen again DO NOT try to start the engine!
(That's one of the reasons The Da always said, "Did you check the oil before you started that engine?")
Dump out all of the oil that has been contaminated with fuel and replace it with fresh oil.
Dec 24, 2013 | Briggs & Stratton Power Products 5,550...
Saturn cuts off when trying to use the a/c
It could be more than one problem.
The cooling fan could be running because the temp sensor is sending the wrong signal to the computer.
The ac compressor or clutch could be bad causing a heavy load on the belt and the engine.
I would unplug the compressor clutch and see if the engine still bogs down with the ac engaged.
Dec 25, 2012 | 2003 Saturn VUE
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
My 96 grand cherokee is shutting down,have replaced almost everything but crank sensor will this be the end of my problems???please help
If the crank sensor is failing, you should get a check engine light and a trouble code for it.
Have you had the computer checked for trouble codes ?
Aug 17, 2012 | Jeep Grand Cherokee Cars & Trucks
Just purchased a 94 Sunbird SE for my son (today) Started fine. Drove for 15 minutes. Shut it down and it sat for 1 hr. Started again after registration and insurance. Drove for 10 minutes. Stopped once...
Take it back to where you got it and make them refund your purchase price. If they refuse and you finianced it go to them, There a law called "The Lemon Law" that makes it unlawful to sell something like that. Sounds like you sure bought one. Don't do anything to it just get hold of the place where you bought it and tell them to come get their junk out of your yard! dhgill1949
May 22, 2011 | 1994 Pontiac Sunbird
Husqvarna RZ4219 42 inch 19.5 HP Briggs & Stratton Zero Turn Mower Logo
183 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
