Question about Camping, Backpacking & Hiking
Flashlight switch will not keep flashlight ON!! What do I do?
  • 1 more comment
  • Dennis Kimmell
    Dennis Kimmell Apr 08, 2015
    Duracell 1000 lumin flashlight (4 C batteries) china chime 1435
  • Dennis Kimmell
    You push the switch on and light comes on for a second then goes right back off!!
  • Dennis Kimmell
    How do I fix it?!!
SOURCE: Maglite 3 D-cell Flashlight -- with D in front of Serial #
I ordered a replacement switch.
Posted on Aug 29, 2008
  • 75 Answers
SOURCE: How is a flashlight both luminous and nonluminous at the same time?
At first light it DOES sound a bit confusing.
First, the definition of the term 'NON-LUMINOUS'; 'Not capable of PRODUCING light but can be capable of REFLECTING light from another source'.
For instance, our MOON is NON-LUMINOUS as it REFLECTS light from the Sun. The SUN is LUMINOUS as it produces light that is REFLECTED off the surface of the moon. And so, LUMINOUS means capable of PRODUCING light.
Now closely examine your flashlight.
The BATTERIES produce electrical energy which is transferred to the BULB which emits light, thus LUMINOUS. The tiny little BULB emits quite a lot of light for its small size. However, the bulb is contained within a concave silvered cone which REFLECTS,(NON-LUMINOUS) gathers and channels the emitted light from the BULB (LUMINOUS) into a BEAM which ILLUMINATES whatever you are pointing the flashlight at.
Our cameras would be just paperweights if there were no NON-LUMINOUS surfaces for the light to REFLECT off of, back into the camera lens, onto the 'plate' thus etching the image. For example, take a photograph in the dark without the flash and what do you get. No LUMINOUS, no NON-LUMINOUS.
And so there we have LUMINOUS and NON-LUMINOUS, ILLUMINATING our lives. Enjoy! :)
Posted on Apr 27, 2009
  • 75 Answers
SOURCE: need to replace switch in my flashlight
Jason, on April 24 I sent you the solution as to how to replace the SWITCH in your Maglite. :)
Posted on May 08, 2009
  • 19 Answers
SOURCE: Flashlight problems
You're experiencing a switch problem, find an authorized service center in your area at www.streamlight.com or send it directly to the factory in Eagleville, PA. If you're handy they can send a switch kit with instructions on how to repair this.
Posted on Aug 28, 2009
  • 205 Answers
SOURCE: Light will not work, batteries good. Switched out
it could be bent contacts
Posted on Oct 14, 2009
Not sure which bit to unscrew when trying change battery in onyx50
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
Apr 06, 2016 | Gerber 22-80144 Onyx 50 Flashlight
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
May 11, 2015 | Stanley Camping, Backpacking & Hiking
How to re-wire the flashlight Makita BML185
You have a battery a globe and a switch. It really only matters matter if you keep the circuit board(CB). Here's how mine was wired.
Red - Battery pos to switch to bottom of CB (BT+)
Red - top of CB (BU+) to pos contact pivot
Black - neg contact pivot to top of CB (BU-)
Black - bottom to CB (BT-) to battery neg
Or you could just bypass the CB altogether, wire the black to the black, and the red to the red. done.
Jul 31, 2012 | Makita 18V Lxt Lithium Ion Rechargeable...
How come flashlights are called flashlights if they don't flash?
In the early days of flashlights, the battery life was very short. So if you needed to use a flashlight, you would turn in on only for a second and then shut it off. Hence, the term flash-light.
Jul 09, 2012 | Camping, Backpacking & Hiking
Flashlight will not keep lighted, only flashes intermittently
i had one extend spring in cap slightly,also check diode is making solid contact with battery
Jan 08, 2011 | Victorinox AAA LED Rubber Grip Flashlight...
Batteries got corroded in the flashlight now I can't get it out. How can I get the battery out?
If you can remove both ends of the flashlight, find a piece of pipe that is slightly smaller in diameter than the inside of your flashlight, hold the flashlight body in one hand and the pipe in the other. place the pipe on top of the batteries then strike the pipe on a heavy hard surface that you are not worried about damaging. The blows should dislodge the batteries. Clean the corrosion thoroghly before putting new batteries in
Jun 14, 2010 | MagLite Mag-Lite& Flashlight
We changed the battery pack and the bulb and it wont come on so the switch is prolly defective where do we find how to repair the flash light
Alot of maglites are problematic with symptoms like this... I have found that the culprit many times is the screw cap on the bottom of the flashlight.
The elecrtrical connection needed between the spring in the end cap, the threads on the cap and the threads in the barrel of the flashlight...
Make sure you twist your spring a bit..the dissimilar metals can actually corrode between the spring and the cap... Then spin the threads a little... Then try the flashlight again...
This procedure may save yourself replacing a switch..
Apr 29, 2010 | MagLite Rechargeable Flashlight System
Flashlight won't turn off
It sounds like the on/off switch is defective. Unscrew the battery cap to keep the light from draining the batteries.
Mar 15, 2010 | Camping, Backpacking & Hiking
Flashlight problems
streamlights have lifetime warranties. Contact them to find a dealer that can fix it. They might even let you send it in to get fixed.
Aug 15, 2009 | Streamlight Stinger XT DC, Black
Camping, Backpacking & Hiking Logo
160 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
