Question about Toshiba Toshbia E-Studio 2540c
FRozen on a print job cant delet the job cant resume the Job unplugged the machine took out all of the print jobs from the computer that were being sent???? Totally frustrated !!!
  • 32 Answers
SOURCE: storing a multiple page job
Simple. Scan your document into your e-filling box. No funny stuff. When you want to print it, select your document. At the bottom of the screen you will find the button settings. It will take you to the main screen. Simply select what you want the machine to do with the document.
Hope it helps
Posted on Feb 21, 2008
  • 60 Answers
SOURCE: Job Reservation Full
It means that the number of reserved jobs has exceeded 100. You can either wait for the reserved jobs to be completed, or check the jobs and delete the reserved jobs
Posted on Nov 11, 2009
  • 628 Answers
SOURCE: toshiba 255 not printing from computer but works as
Did u installed the printer kit?
What kind of interface u're using, RJ45/network or USB ?
Posted on Dec 21, 2009
nonontech
  • 4737 Answers
SOURCE: I have printed this file many times, sent file to
Try this, Press the Cancel button several times, leave it for few minutes, and then Turn off and switch on while you keep pressing the cancel button. If there's memory installed on the Dimm slot, remove it and re-install it.
Also check the print queue, Start > Printers and Faxes > double-click the printer's icon, click "printer" on the menu and select "Cancel all Documents" click "Ok" and restart both computer and the Machine. (I assume your computer with windows Operating System Installed.)
Sometimes reseating the cartridges and drum is helpful. You can give a try. But since you can make copies, I don't suspect the issue's related to the machine, but with the computer and memory.
Disconnect and reconnect the cable (usb) connecting the machine to the computer.
Good luck.
Thanks for using FixYa.
Posted on Aug 13, 2010
SOURCE: The printer will not print any documents from any of the computers and its not saying anything under the job status
- if connected via usb ,check cable and usb port
- check in properties if printer status is enabled and use printer with connection or use printer offline is selected
- if connected via ethernet ping the ip adress and check cable
-if connected right on the copier without a switch in between you need a reversed ethernet cable else you need a straight one through the switch
Posted on Jul 30, 2012
Unpause print job hp office jet
There are a couple of ways.
Unplug the printer from the wall, count to 10 and plug back in, that clears the memory.
or
On the computer, there are two ways.
1. Go to Devices - Printers, Right click on the printer, and Properties, Print Jobs or double click the icon to get straight to Print Jobs in the Queue. Highlight the doc, right click, Resume or Delete.
2. Click the Print icon in the bottom right of the screen. It may be behind the upward facing arrow, click there and look for the printer icon.
Dec 11, 2016 | HP Office Equipment & Supplies
I have try to delete a printing job and it will not print and will not allow anything to be print. However, I was able to delete the other jobs after the first job but the first job willnot delete
Sometimes if the printer cable is unplugged it will reset. Try that. Also the printer menu should include cancel print jobs. Is that cleared? I would also turn off computer for a moment, and turn back on. Thqat may clear the print job.....
Apr 19, 2014 | HP Photosmart C4100
Print job frozen on Brother MFC-6490CW
Power down your printer to clear the cache and re load from page 3.
Jun 20, 2017 | Brother MFC 6490CW InkJet Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
I'm trying to delete a print job and the job will not delete. I can not uninstall the printer software and reinstall it because the job is still trying to delete and un pluging it didnt work either. I...
Try turning off BOTH the printer and computer and unplugging the printer from the PC. Reboot PC and printer, then plug the printer to the PC. This should delete any remaining print jobs.
Jan 14, 2011 | Lexmark X2650 All-In-One InkJet Printer
Deleteing an incoming fax job that has stopped printer . The incoming job has the incorrect paper size.. and i cant choose that paper size. I can not delete the job as usual, the delete button does not...
On most Bizhub Copiers if you have something stuck in memory that is tying up the machine you can turn it off and unplug it from the wall for 10-15 seconds and then turn it back on. Doing this will erase the Random Access Memory and should clear all fax and print jobs from the machine.
Aug 12, 2009 | Minolta bizhub 200 All-In-One Printer
There is a frozen deleted job in my print queue
turn off the printer and unplug it from the computer. after which you restart computer
Mar 27, 2009 | Office Equipment & Supplies
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Toshiba Toshbia E-Studio 2540c Logo
29 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
