Question about Acer Aspire 5733-6607 Intel Core I3-370M 2.4GHz 4Gb 500Gb DVD/-Rw 15
5733 screen flickers just white lines but will work ok with external screen
  • 70 Answers
Replacing screen will solve the problem
Posted on Apr 06, 2015
  • Acer Master
  • 2,072 Answers
Sounds like the screen is failing then. The screens are typically between $40-120 and you should be able to find one on amazon.com
I would consider this a medium difficulty repair.
Here is a link to a youtube video detailing the procedure.
Laptop screen replacement How to replace laptop screen Acer Aspire 5733...
2 Suggested Answers
SOURCE: monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Posted on Mar 25, 2009
How do I stop flickering horizontal lines on Dell laptop?
Check the GPU is ok by using an external screen. If the external screen is ok, replace the laptop screen.
Sep 10, 2014 | Computers & Internet
When i connect my laptop via linetek vga to av converter ,it show black & white output on my tv.
you have to go into the graphics card adapter properties program and change the screen res of the affected and you must also enable multi screens in the same program. laptop #1 external monitor #2 do not use extended to other monitor rhen you get less
Sep 30, 2013 | Acer Aspire 5733...
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
Lg env touch internal screen flickers white/colors after h20 expo
go ahead and take it apart... but be extra careful with the flex part,, dont use aclohol it may corrode some parts, try using lacquer flo, and dry it out with mild heat using hair blower or some sorts
maybe that would fix it, but if the lines you are saying doesnt go off, well you have no choice but to replace the lcd itself
Nov 10, 2009 | LG enV VX9900 Cellular Phone
I get a blue screen with flickering white lines
It couuld be the invertor is burning out.
If you boot into safe mode and the same thing happens, it is not a software problem or drivers.
Sep 28, 2009 | Dell Inspiron 1501 PC Notebook
Screen with a weird flickering and coloring on Acer 5715Z laptop
To determine if he video card is faulty, connect an external monitor to the laptop's external video port, then power up the external monitor and then the laptop. The video info should automaticall switch to the external monitor. If you see anormal Windows image on the monitor then the video card is OK and the fault is with the LCD screen, could be the video cable/connector. Try reseating the video cable/connector to the motherboard.
If the video card is faulty and because it is part of the motherboard it is extremely dificult to repair, usually a replacement motherboard is required. This may not be a cost effective solution depending the age of the laptop. You could remove the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB drive.
Aug 16, 2009 | Acer Computers & Internet
Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Acer Aspire 5733-6607 Intel Core I3-370M 2.4GHz 4Gb 500Gb DVD/-Rw 15 Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
