Question about Frigidaire Dishwashers
Wont turn on. Is there a switch to start.
No electricity nor water
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, friend!
From the information you have provided your Frigidaire dishwasher is not turning on. There is not a switch to turn on your dishwasher. You should be able to use the keypad and select the cycle and press the start button this will initiate your dishwasher. You may need to check the installation to assure that everything has been connected properly. If your connections are correct you may also want to review your household circuit to make sure it has not been flipped. If you continue to have an issue with your dishwasher you may need to have a technician out to perform a proper diagnosis and repair. I hope this information is helpful for you. -Matt
Posted on Apr 13, 2015
Whirlpool stylemaster 4217141 water won't stop filling the machine and it wont start agitating
drain machine and check the water level pressure switch air pipe
that's connected to it ,it's posably blocked stopping the switch from operating. safety disconnect from mains electrical supply before removing any covers.
Nov 13, 2016 | Whirlpool Washing Machines
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
My karcher pressure did turn on but stopped working altogether now wont turn on
Make sure that your circuit breaker did not go off and you have power..
Turn on the water after connecting the hoses. Then connect an ohm meter to the hot and ground legs of the male power plug. Push the on/off button to on and then pull the trigger. When you do that your ohm meter should indicate the resistance of the motor windings. If the resistance still stays at zero, then 1 - your motor is burnt out, 2 - the on/off switch is not working, 3 - the water pressure switch is electrically open. Check all three for proper operation and replace as needed.
Apr 01, 2014 | Karcher Garden
The switch does not automatically turn off when the water boils. If left alone all the water will boil out.
The switch has to turn off when the water boils as the heat generated must cut off the switch. If this wont work the bimetal is not working and the switch is not responding.
You will need to replace the switch. Please contact the dealership for the spare.
check this link for spare:
http://www.espares.co.uk/brands/kettles/p/1102
Sep 21, 2011 | Oster (3211) Electric Kettle
While cooking on my GE electric oven today I spilled water over the stove top by accident, now the iginite pilot wont stop sparking, what can I do to fix it? other than unplugging the oven as a quick...
If it's just water, unplug it for a couple of days and turn the switch back and forth a few times during these couple of days. The water should evaporate and your cooktop should start working again.If this did not help - one of the burner switches (or assembly with all switches and wiring, depending on model) will need replacement
Apr 03, 2010 | GE JKS06BFBB Electric Single Oven
Hot water wont fire up when hot tap is turned on . but firing up for radiators ok
Check the diverter valve is operating when hot is on demand. Depending on the boiler [valve types differ] most have a small piston [biro refill diameter] protruding which operates an electrical switch/contact.
replace switch.if valve piston works but not the switch OR it piston not working
replace valve [or diaphragm inside]
Nov 15, 2009 | Water Heaters
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Overheats, and wont switch gears at times.
Well overheating and not starting are possibly 2 different issues. Oil is not the cause of overheating. Thermostat, water pump, electric fans and viscous fan are causes for overheating plus the sensors that control the fans. Not starting could be caused by the overheating but most likely its a fuel or ignition issue.
Jul 29, 2009 | 1997 Mercedes-Benz E-Class
GE electric dryer wont start
The first thing I would do is check your door switch. When the door closes it hits a switch to tell the machine it's safe to start.
Hope this helps!?
Jun 19, 2009 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Dishwashers Logo
227 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
