Question about Air Tools & Compressors
I need parts for a Dayton 3Z999A w/ a 3Z960 compressor head. Any ideas?
Looking for a parts list for a Dayton 3Z372b electric hoist.
Dayton Hoist Parts - Ace Industries, Inc.
https://www.aceindustries.com/m-53-dayton-hoist-parts.aspx
Dayton Hoist Parts Online. Certified OEM DaytonParts in Stock Helpful Diagrams to Find Parts Fast. ...Dayton Electric Chain Hoist Parts. Basic Hoist(Figure 12) ...
[PDF]Dayton® Electric Chain Hoists - Ace Industries, Inc.
www.aceindustries.com/pdfs/Dayton/DaytonElectricChain-JLCManual.pdf
Dayton electric chain hoists are rugged, portablehoists that provide quick, precise ... Other features that ensure the safe operation of Dayton electricchain hoists.
Dayton Hoists Online - Ace Industries, Inc.
www.aceindustries.com/m-52-dayton.aspx
Coffing hoists and the Grainger Dayton electric hoists are the same identical units. The only
Apr 19, 2016 | Dayton Heating & Cooling
How can I adjust the torque settings?
PDF]SD Compressor Service Guide - Sanden
www.sanden.com/productlibrary/manuals/sd_service_guide_rev_2.pdf
6.6.2 Suction Gas Condition. 6.6.3 Ambient ... Internal compressor pressure can be relieved by removing shipping caps ... Never leave PAG oil exposed to air for a prolonged time. Tightly ..... Place rotor pulley shaft protector (Puller set) over the exposed shaft. 4. ... Replace retaining nut and torque to specification. 1/2-20: 20- ...
Speedaire Air Compressors - About Air Compressors
www.about-air-compressors.com/speedaire.html
when i try to start my gas compressor it backfires why 5.5 speedaire by dayton, serial ... cant find cylinder head torque specs for 35w347 need the torque specs to properly break .... I also need to know how to change the oil on the 1z943b motor ...
[PDF]80 Gallon Industrial Air Compressor - Mi-T-M Corporation
Dec 08, 2015 | Air Tools & Compressors
I need Pressure Regulator for Speedaire 3Z355H
The pressure regulator does not have to be specific for your compressor. You just need to get the right line size and pressure range you are needing. You might be able to get one from Home Despot or Lowest, but I would look on Amazon. I am sure you can get it from Grainger, but you will pay a premium price. If you are on a budget, check Harbor Freight if you can.
Aug 27, 2012 | Dayton Audio Dayton Speedaire Air...
Dayton model 6k754m 1 hp motor compressor duty dual voltage turns ccw and needs to turn cw leed t2 &t3 need connection diagram.
Grainger parts can send you the diagram if it is missing or illedgible from the motor nameplate. Contact them at http://www.grainger.com/Grainger/RP_cont.jsp or 1-800-323-0620.
John
Aug 23, 2011 | Dayton Dryers
I need ignitors for heater model number 3e219e
The part number for the ignitor kit is PP200 (new number) Old number was PN HA 1000.
Also from the parts list, this PN: 102548-03
Parts list:
http://www.bealsmotor.com/105553_219E.html
Burner head parts: (Ignitor is item 5)
http://www.bealsmotor.com/105553_burner.html
Actual Ignitor Kit:
http://www.amazon.com/Desa-International-Hot-Surface-Ignitor/dp/B000DZDPVI $39.95 + shipping
Downloadable manual: http://www.desatech.com/manuals/Construction%20Heaters/105553-01.pdf
Dayton Portable
Oil-Fired Heaters
PARTS:
Ph. 1-800-323-0620
24 hrs / 365 days a year
105553
2E510F, 2E511F, 3E218E, 3E219E
Please provide following information:
-Model number
-Serial number (if any)
-Part description and number as shown in parts list
102548-03 (part you need)
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Dayton Heating & Cooling
I need i shop manual for a dayton speedaire model 3z244d
The dayton brand is sold by Grainger.
Check for the manual at grainger.com they also have a cust. service number that maybe can help you...
heatman101
Sep 28, 2010 | Dayton Audio Dayton Speedaire Air...
Parts lists (i.e. rods, crankshaft, rings) for
Information about your unit can be faxed to you by calling the number below:
From the USA, please contact us at 1-800-323-0620
It may be easier however to look for the model number of the pump only as the 3z497 reference number is of the the complete unit. Look for model number or information on the pump itself and check that number at www.grainger.com. I believe that you have a two stage pump that may still be sold seperately. Good luck on your repair.
Jul 22, 2010 | Dayton Audio Dayton Speedaire Air...
What is the cfm rating on a dayton gas powered air compressor, model # 5f2168
I would try calling Grainger.ask for tech support on their compressor.you can also order parts for this if they are still available.
Sep 26, 2009 | Air Tools & Compressors
Constant popping
THE POPPING SOUND IS PROBABLY COMING FROM A PRESSURE RELEIF VALVE ON THE HEAD OR INNERCOOLER. THIS TYPICALLY MEANS THE VALVES IN THE HEAD ARE BAD AND RARELY THIS VALVE IS BAD. DO NOT PLUG THIS PORT. YOU CAN TRY CHANGING THIS SAFETY VALVE-PAY ATTENTION TO THE PSI RATING ON THE SIDE. SINCE ITS A DAYTON IT CAME FROM GRAINGER AND YOU CAN GET PARTS FROM GRAINGERS 1-800 PARTS SERVICE. TRY TO FIND A 5 DIGIT PART # SOMEWHERE LIKE 5Y670, ETC. YOU CAN PROBABLY GET A VALVE REPAIR KIT OR THE ENTIRE VALVE PLATES. PAY ATTENTION WHEN DISASSEMBLING AND MARK DIRECTION OF PARTS. HOPE THIS HELPS, JODY
Apr 22, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
251 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
