Question about Philips 50PF9731D/37 50 in. Plasma Television
No display on right side of picture
MISSING RIGHT SIDE OF PICTURE
    Top Expert:
  • Philips Master
  • 74,198 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on Apr 17, 2015
    Scholar:
  • 146 Answers
This is an LCD television, you may find at the top of the LCD display a module referred to as a t-con module (timing control module).
There are usually two ribbon cables that make connection from the T-con to the display itself. Check these cables for corrosion or burn marks that might be preventing video passing from t-con the the display.
  • 4234 Answers
SOURCE: Picture problem
If the set is no longer under warranty, open up the back and reseat all of the connectors and cables. You are seeing a heat related connection problem. If it is still in warranty, bring it in for warranty repair. The other possibility is a heat related connection at the processing chip(s). This is a more complicated repair that should only be done by an experienced tech that works with surface mounted components.
Keep us posted.
Dan
Posted on Apr 23, 2008
  • 197 Answers
SOURCE: Screen Shift PLZ HELP
burn in run  a white screen
Posted on Jun 07, 2009
SOURCE: 26PF9956/12
Take the back off the unit. There are 2 20 pin cables that go to a small board that sits on the right side (viewed from the rear) spray the back of the plugs with contact cleaner and wiggle these cables where they plug into the small board.
Posted on Jul 20, 2009
  • 1779 Answers
SOURCE: phillips tv model #42pf5321d/37 we replace the
You should have downloaded the eprom information onto a usb stick then transfered it back to the new board, or just removed the eprom off the old board onto the new. It is my recommendation to have an authorized service center come out and realign it within the factory service mode.
Posted on Dec 11, 2009
techman007
  • 1112 Answers
SOURCE: no picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Posted on Jan 13, 2010
What is the problem with my lg plasma tv 42". The picture is showing on right side but the left side is black.
Most often when part of the picture is missing like that you have a bad T-CON board.
Aug 10, 2016 | LG Televison & Video
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Left side is dark and right side is good
The LCD sets use backlights and also a pair (some models combine both into one unit) of inverters- one drives left side and the other right side.
You could have a bad inverter (some versions call it T-con) or even a bad display panel(main screen unit).
In most cases this is not a do it yourself repair.
May 17, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have this model and its been giving me probem with the picture coming on and if it came on only half the picture come on
It sounds like the inverter board for that side of set is bad(uses either one large or two small boards--if two small the one for that side is bad OR the main display panel itself is bad.
Seen more than a few of this brand come on with picture on one side and then the other side gets real bright for a few seconds and set shuts down.
Shutdown circuit will detect something is drawing a lot of current and shut set off.
This if the display panel itself is bad will not be worth fixing.
Some Plasma sets have same issue and use names like sustain board etc for the same function--they drive the display panel left side, right side or top and bottom.
Apr 12, 2012 | Philips 47PFL7403D 47 in. LCD TV
Far right side of the text or picture missing on Dell 3100cn.
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Sep 30, 2009 | Dell 3100cn Laser Printer
Offset picture
You need to change the Display menu for picture mode to 16:9
no wide fit or scan fit.
Jan 28, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Sep 13, 2008 | Mitsubishi CS-40503 TV
Bosch Dishwasher Side Hose
The hose on the right is a breather and should not be connected.
Sep 17, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
Philips 50PF9731D/37 50 in. Plasma Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
