Question about Pool & Spa
My older dream maker spa leaks only when pump is running. I have checked all areas I can see, no water. leaks about 2" in 12 hrs. Is the drain in the footwell accesable from below?
    Top Expert:
  • Pool & Spa Master
  • 8,177 Answers
Check between pump and motor
Posted on May 11, 2016
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
SOURCE: my spa leaks
Good luck, I'm in the process of chipping away at the foam 3 days so far, still have not found leak, Tried everything dyed water, but with the way they do the STUPID foam the water could be dripping 3ft away from leak... **** poor design and the can foam to fill it back up is gonna cost a small fortune,,
Posted on Sep 08, 2009
SOURCE: how do you replace jets on dream maker spa X-500
There is a tool that comes with the spa, instructions are in the owners manual. If you don't have the manual you can download it here
http://www.dreammakerspas.com/_PDFs/0607l.pdf
If you don't have the tool you can order one from Dream Maker.
Posted on Nov 04, 2009
  • 13764 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Keeps blowing 15 amp fuse on main cpu
A qualified Electrician should do this due to safety reasons.
Gain access to the stick heater:
http://www.spaplaceinc.com/proddetail.php?prod=461257
Disconnect one wire and tape it off. Then run the unit for the period that you said it blows the fuse of 2 - 3 hours. If the fuse does not blow then the heater is bad. If the fuse still blows most likely the motor/pump is dragging.
Motor/pump assy:
http://www.spaplaceinc.com/proddetail.php?prod=403627
There is a possibility of a wire that got pinched or chaffed somewhere and the possibility that water has damaged the electrical runs on the main board if there is an internal leak. Usually the problem is either the heater (Most often) or the Motor Pump Assy.
You unit has a plastic water jacket around the motor to keep it from overheating... sometimes this water jacket vibrates loose, then gets a hole in it and sprays water into the motor. If yours has a leak.... you can actually fix the hole with Marine Epoxy 2 part. The Epoxy will dry in about 4 hours to the point you can re-install the cooling jacket.
Thanks for using FixYa.
Kelly
Apr 04, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
143 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
