Question about Water Water Heaters
Hi im not getting constant hot water and also it makes a noise like a jet taking off i have read the trouble shooting section and the checks says its normal
  • Water Master
  • 5,089 Answers
Http://waterheatertimer.org/How-to-fix-water-heater.html
http://waterheatertimer.org/Crossover.html
Unclear what type of heater
Links above can help identify type of heater... and common reason for hot not arriving at faucet
Gene
Water Heater Timers Save Money
Posted on Apr 06, 2015
How do I trouble shoot a residential water heater
Hi Michael:
First off you have to determine what the SYMPTOM is that you are experiencing.
Example:
- water too hot
- puddle under tank
- very little hot water.
Then you can ask the FIXYA gang for help with the problem, or
You can research it yourself.
Jul 18, 2015 | Water Water Heaters
Can't light pilot light on hot water service. Gas to property is connected as the gas stove works.
There should be a trouble shoot guide on the hot water tank. I have had to do this many times. You just need to read the trouble shooting guide & be very careful. I hope this works for you.
D :)
Feb 01, 2013 | Water Heaters
Puma 80 potterton hot water on and off
Boiler compartment ventilation will not stop you getting hot water . Its sounds like you have problems with a sensor or the water section on the boiler .
Apr 20, 2017 | Water Heaters
No hot water coming out. ignition comes on ,but no lighting of gas. There is gas in bottle and it's on as normal.Works one day , doesn't the next.I cannot remember if there was a pilot light before!
check for pilot but im sure that the pilot is on demand thats what makes these things so cool and inexpensive to operate. try having someone turn on the hot water while looking for ignition. if there is nothing it may be a relay. im not sure but if you open it up check for a 3 amp fuse its green. all the new furnaces with mother boards have a fuse. I am not really a heating guy but i have been looking into on demand systems and sat in a training session at the plumbing supply. never hurts to try and help.
if its not a fuse or the ingniter isnt functioning you may need to call a heating person who knows on demand or check Bosch on line maybe they have the trouble shooting guide if you dont.
sorry that all i can suggest hope it helps
Dec 04, 2010 | Bosch & Tankless LP Hot Water Heater
Hi im having trouble lighting my water heater and turn the water to hot. it says push and hold the knob and repeatedly press until pilot ignites.
after pilot lite you got to hold it down for 45 sec before you can turn it on..if you still having trouble get a qualify technician to relite it.
Aug 09, 2010 | Honeywell Water Heaters
Water is too cool for shower. Is there a thermostat?
I do not believe there is a separate thermostat. However the installation guide: http://www.eemaxinc.com/assets/files/FLOCO-install.pdf gives some trouble-shooting steps. More detailed trouble-shooting is here: http://www.eemaxinc.com/assets/files/floco-trouble.pdf
If the indicator light is off when the hot water valve is open: check your circuit breaker and the flow rate of water into the water heater (it must be over 1/2 gallon per minute). If those are okay, check the resistance of the element with a multimeter - 20 Ohms or less is good, 10,000 Ohms or so indicates a bad element. The trouble-shooting guide indicates the proper points to test.
If the indicator light is on, then check the flow rate at the shower head or faucet (reduce the flow until the water comes out hot), check that the unit is installed to the correct voltage supply and the resistance of the element.
If those are okay, then check that the printed circuit board is correctly installed and that the inlet filter isn't clogged.
After that, it's call the company for their technical support.
Dec 18, 2009 | Eemax EX95 "Flow Controlled" Electric...
Beeping noise
E2 means hot water over shot, make sure to check boiler hot water system to make sure zone valve or control is staying closed when the call for boiler hot water to the water heater is isolated. Sometimes a zone valve will fail open or not close properly causing hot boiler water to constantly feed the water heater.
Dec 08, 2009 | Amtrol Water Heaters
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
My electric reliance water heater is making a constant noise
it might be hard water in the heater. the hard water flakes and when your water heater turns on it creates some movement in those hard water flakes and makes a popping and hissing noise then when it comes to temperature it should stop. the temperature and pressure relief valve shouldn't make this noise. but if you stick your finger in the pipe and it is wet then you might have problems some where else. let me know if it is
Jul 29, 2009 | RELIANCE ELECTRIC WATER HEATER
No hot water
check the flue and make sure nothing is in it, nothing can be obstucting the flue or it will shut down on carbon monixide make sure nothing is in it if you have to take it apart do so it just slips together
Jun 07, 2009 | Rheem Tankless Hot Water Heater...
Water Heaters Logo
66 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
